 Post subject: Clean a Platter
PostPosted: May 19th, 2006, 9:32
Hy does any one if a Ultrasonic Cleaner could help to try to clean a platter from a hard disk wich was opened by another people and left some dust and finger print
 Post subject:
PostPosted: May 19th, 2006, 10:50
Hello Alberto,
I would use acetone with cotton swab and a brush.
 Post subject: Re: Clean a Platter
PostPosted: May 19th, 2006, 16:34
beto wrote:
Hy does any one know if a Ultrasonic Cleaner could help to try to clean a platter from a hard disk wich was opened by another people and left some dust and finger print
PostPosted: May 21st, 2006, 0:01
beto wrote:
Hy does any one if a Ultrasonic Cleaner could help to try to clean a platter from a hard disk wich was opened by another people and left some dust and finger printThanks
I don't know if Pepe is kidding, but I wouldn't put acetone near anything. Not real acetone, anyway. It can dissolve plastic and is a pretty heavy duty solvent. I have used 99% alcohol effectively. I don't know about the long term effects because I have read some platters are designed with an in-built lubrication. I notice when I clean with 99% that it leaves a thin, oily film that can be buffed with a very soft , lint-free cloth. The dust can be blown off with a can of compressed air that's not held too closely.
I don't know how an ultrasonic cleaner can remove organic matter that a fingerprint would leave. It's pretty sticky, and smears. Any time I've cleaned with the 99% alcohol, the platter surface has been left really shiny and the heads don't leave tracks on them. Also, if the platters have any kind of glass in them, what are the chances of putting hairline cracks in the glass?
From my past experience with disk drives, many years ago, I have witnessed the accumulation of debris on the head itself. If it's been running over organic matter, you can bet it has a build up on the head suface. The question arises as to how to clean the heads....they are so fragile.
PostPosted: June 5th, 2006, 16:30
Thats right, use acetone and cotton swab. Proved for wd drives.
PostPosted: June 5th, 2006, 18:23
are we talking about the same acetone? It dissolves laquer-based paint. It's also used by women to remove nail-polish. In other words, it's a heavy-duty solvent. It could seriously damage a platter surface if the platter is made of a substance that reacts with the acetone.
If it is recommended for WD drives I don't know why. I'd like to know more about that. Do you have a URL?
99% isopropyl alcohol does a real good job with carbon-based, organic material and greasy substances. It also dries very quickly leaving little or no residue. If there is residue, it was something it dissolved, like oil on the surface.
PostPosted: June 6th, 2006, 12:39
just give it a chance :)
It is important that U get really clean acetone, mine is over 99.5%, but there may be even more pure stuff.
PostPosted: June 6th, 2006, 16:30
It is important that U get really clean acetone, mine is over 99.5%, but there may be even more pure stuff.pepe
hey, pepe, how's it going?
I'll check it out...thanks for the tip.
Users browsing this forum: Google [Bot] and 211 guests
