 Post subject: 2B020H1 problem
PostPosted: August 19th, 2006, 15:08
ATHENA DSP
WAH21PBO
11A 05A KEBE
A5FBA
2B020H11110511
-first the drive identification bios athena
then I use copyr hot swap similar drive, but not KEBE and not A5FBA
the clon is good but only 10million sectors is good but rest are bad
-second the bad drive is good, bios is recognized good, and the ID is good, but the importand data are not back
my ask: what happend, then the drive will good, and how can i set back the all sectors
 Post subject:
PostPosted: August 20th, 2006, 7:36
did u repair another group moudule or any other module except the SWAP
group module. if u did regenerate translator .
or else try recovering ur data ..
 Post subject: re
PostPosted: August 20th, 2006, 9:40
No I have not repaird any modules.
 Post subject:
PostPosted: August 20th, 2006, 12:52
try regenrate translator that is the last solution i can think off
 Post subject: re
PostPosted: August 21st, 2006, 5:38
I found 2 module group errors (data copy 1 and data copy 2), i repaird those, but the disk have not worked good and i don't look the important data.
 Post subject:
PostPosted: August 21st, 2006, 13:51
Hello KeFe,
send it to me!
 Post subject: re
PostPosted: August 23rd, 2006, 0:42
thanks, but I would like save that
 Post subject:
PostPosted: August 23rd, 2006, 3:41
OK, good luck! :)
regards,
 Post subject:
PostPosted: August 27th, 2006, 6:31
then u must have replaced the wrong structure modules which havent matched the rom no of the drive
Users browsing this forum: No registered users and 333 guests
