 Post subject: Raid 5 Information
PostPosted: September 3rd, 2006, 9:20
hi
I need to know how DATA read and write in Raid 5 with 4 H.D.D :?:
thanks
 Post subject:
PostPosted: September 3rd, 2006, 13:16
Your Message is not very clear ,please elaborate
 Post subject:
PostPosted: September 3rd, 2006, 14:26
for exampel in RAID 5 with 3 H.D.D DATA write as below:
6 block = Block 1 in H.D.D 1 , Block 2 in H.D.D 2, Parity 1,2 in H.D.D 3
Block 3,4 in H.D.D 1 , Block 3 in H.D.D 2 , Block 4 in H.D.D 3
Block 5 in H.D.D 1 , Block 5,6 in H.D.D 2 , Block 6 in H.D.D 3
Now I need to konw how write in 4 H.D.D?
 Post subject:
PostPosted: September 3rd, 2006, 17:57
Hi mehran,
get an old raid box with say three drives and an adaptec controller.
1. use hardware raid, create OS and then copy a large text file (1MB),
then study how this text file is written to the drives.
2. Use software raid W2000 and do the same as in 1..
3. Then try get an old HP / Compaq raid box and try the same as in 1. and 2.
Then you will have learnt a lot about RAID 5
and you will then know how to start to recover RAID 5 for some money.
 Post subject:
PostPosted: September 4th, 2006, 6:09
AFAIK each controller does it in its own way, so U have to find out the sequence, block size and offset values for your particular case.
regards,
Users browsing this forum: No registered users and 259 guests
