 Post subject: English translation of MxHelp readme.
PostPosted: September 4th, 2006, 7:02
I used http://babelfish.altavista.com to do this. It needs some work now to make it a bit more comprehensible to English type people. ;)
Description MxHelp for Windows ver. 2.0.
1. Search for the module of passport and its mapping.
2. Search For the module Of specification.
3. The search for loaded PZU, is derived:
- Check sum.
- The version of microprogram. New
- Status of loaded PZU. New
4. Conclusion from LDR:
- the check sum of the loaded BY PZU in LDR.
- check sum of the very LDR. of the version of microprogram. New
- status of loaded PZU. New
- to what family belongs LDR.
5. possibility of renaming LDR:
- in the check sum of loaded PZU.
- the version of microprogram. New (E7CF_VAM51JJZ.LDR)
6. There is the possibility to tune the survey of passport on your desire into MxHelp.ini and to add the
necessary parameters of conclusion or to remove the unnecessary to you. Possibility to add new models
nezanesennye into this list and their parameters.
New in ini are added the parameters for the work with LDR.
Contents of the ravine.
Only passport.
Family :Calypso
Name :DiamondMax Plus 9
Model :6Y080M042541AC
Model 1 :6Y080M2
Code FW :YAR51EW0
Serial :Y21GL3AE
Ata :SATA/150 HDD
LBA :160086528
Date (Time) :27.4.2004 (4:46)
Alphabetic value :KMGA
PCBA Pn. IDE Label :T8FYA
PCBA Config :54B
Unique :1AA
HDA Module :42A
PGT :PGT CASATA2.20
Cod :203
None :K118
+5V :670
+12V :960
Ver. Module :Q8.39
Check sum ROM :A355
Log $MxHelp.txt remains into the directory with the modules.
Editing MxHelp.ini:
[Mod] the list of the search for the passport
2F=Ares 64
2B=Athena
2R=Nike
4D=Romulus
4G=Neptune
4R=Falcon
6Y=Calypso
6E=N40P
5T=Rigel
Example of tuning the passport:
[Mod]
2F=Ares 64
(so it appears in $MxHelp.txt Family:Ares 64)
2F we search for the name of passport in the modules, if they found (=) that it was concluded the name Ares 64
and we pass to the parameters of passport.
[2F] Passport.
Name=S213,10
Model=S130,14
Model 1=S200,7
Code FW=S152,8
Serial=S0,8
Ata=S238,24
Size=S263,5
LBA=#180,4
Date (Time)=D19,5
Alphabetic value=S88,4
PCBA Pn. IDE Label=S344,5
PCBA Config=S70,3
Unique=S84,3
HDA Module=S64,3
None1=S184,14
Cod=#174,2
None=S57,4
+5V=S288,3
+12V=S292,3
Ver. Module=S505,5
Let us examine some values.
Name=S213,10
(so it appears in the ravine $MxHelp.txt Name:DiamondMax Plus 9)
Name-the name of position.
S- it indicates that we read text value.
213,10- the parameters of reading. From xxx of the address xx of values.
LBA=#180,4
(so it appears in the ravine $MxHelp.txt LBA:160086528)
LBA-the name of position.
#- indicates that we read Hex we transfer into Dec.
180,4- the parameters of reading. From xxx of the address x of values.
Date (Time)=D19,5
(so it appears in the ravine $MxHelp.txt Date (Time):27.4.2004 (4:46))
Date (Time)-the name of position.
D- it indicates that we read the parameter of date.
19,5- the parameters of reading. From xx the address of 5 values.
If it did not be located in [ Mod ] the passport, then program passes to the passport [ 00 ] Default
Example of the tuning LDR:
In order to make a search for microprogram YAR51EW0 from Calypso necessary to write down in ini thus.
[LDR]
YR=6Y_Calypso Ardent
YR - parameters of search.
6Y_Calypso Ardent - the designation of the parameters of family.
Successes in the repairs.
Laletin Vyacheslav.
All observations and proposals to send.
vyacheslav@infocentre.khakasnet.ru
http://hddutil.icentre.ru
Users browsing this forum: hwfix888 and 7 guests
