 Post subject: Hard get detected in Bios but show fail messege after POST
PostPosted: September 22nd, 2006, 17:01
Need Urgent help on Hard is issue.
I am having 20GB Maxtor Hard disk. Model : 2B02H1
1) It is getting easily detected BIOS.
2) But after that when computer boot [post] it says primary master hard disk fail.
3) If continue by pressing F1 it does not get recognized by fdisk or XP setup.
4) If any another perfectly fine working hard disk attach even on another IDE slot that also say as fail.
[ Primary master fail] [ Secondary master fail]
Same thing appear even if swap both the hard disk.
I belive this might have happen as primary partition is not formated & I made extended partition active using fdisk of win98.
if I get some how access of hard disk & reformat may resolve my problem.
But under BIOS auto detect IDE hard drive is getting detected but not while booting computer. & Gives hard disk fail message.
So is there any utility which can detect hard disk even if it get fail to recognize while system boot. & not getting recognize by fdisk.
 Post subject:
PostPosted: September 24th, 2006, 4:19
The Hard disk firmware is corrupted u need to restore the firmware .
u can use the Salvation data firmware repairer <DEMO> for fixing the 2b020h1 hdd .
download the demo from http://www.salvationdata.com
Users browsing this forum: Google [Bot] and 26 guests
