 Post subject: WD800 sometimes ok sometimes not
PostPosted: September 25th, 2006, 22:47
I received a WB800 hdd for recovery. The problem is the disk spin normally after a while (les than 30 seconds) it stops spinning., and start again. There is no knocking sound. Everything seems normal than stop spinning sometimes.
It is recognized by bios some times correctly. But it gives an error as secondary hdd fails F1 to continue.
Any suggestions?
Thanks in advance.
Baha Cevik
 Post subject:
PostPosted: September 26th, 2006, 4:23
Banned User
its FW is damaged
 Post subject:
PostPosted: September 26th, 2006, 4:59
arfaizy13 wrote:
its FW is damaged
when you shoot from the hip - you miss very often.
In this case most likely one head not reading correctly
and fw is just perfect.
 Post subject:
PostPosted: September 29th, 2006, 15:40
Banned User
coffeebean wrote:
arfaizy13 wrote:
its FW is damaged
haha....i know the problem but i was testing ur knowledge
 Post subject:
PostPosted: September 29th, 2006, 19:10
arfaizy13
Please do not test anyone's knowledge anymore. This is not needed on this forum.
Thanks.
 Post subject:
PostPosted: September 30th, 2006, 3:14
I had anothet case in samsung but even one head have problem I could able to get most of the data.
Do I need to change the head?
What do you suggest?
Thanks.
Baha Cevik
Istanbul - TURKEY
 Post subject:
PostPosted: September 30th, 2006, 4:24
Banned User
maysoft wrote:
arfaizy13
Thanks.
ok.. i will not do in future
 Post subject:
PostPosted: October 1st, 2006, 5:11
Dont Change he head disable it . And enable the good head .
 Post subject:
PostPosted: October 1st, 2006, 7:03
Can you tell me more clearly, after @bahacevik do that, what happen and how to recover data after disable the head?
 Post subject:
PostPosted: October 1st, 2006, 7:30
he is telling that the hdd detects and runs sometimes and sometimes not
so when it runs sometimes then get the data .
To repair the hdd use pc3k isa to disable the faulty head and get repalce it with good head .
 Post subject:
PostPosted: October 3rd, 2006, 2:37
I have made a copy of bad Samsung hdd with Media Tools and able to get %80 of the data. Some jpeg files are bad but most of them are ok. Customer accept the data.
Baha Cevik
Istanbul - TURKEY
Users browsing this forum: Bing [Bot] and 113 guests
