 Post subject: Fujitsu MHT2030AT ATA Password Recover
PostPosted: February 28th, 2006, 13:04
Hello
I got an hdd which is ATA Password protected. I tried to remove the password with mhdd by using the unlock and remove passwords (command) but unsuccessful. I have to recover the data of this drive.
Somebody can help me in this regard.
Can somebody give me the Master password or any solution to reset the password to empty or to recover the data .
Want to do it immediately, you can PM me or email me at infinixf@gmail.com
Thanks in Advance.
Faisal.
 Post subject:
PostPosted: February 28th, 2006, 19:17
Hi Faisal,
You can take a look onto the A-FF Repair Station ( http://a-ff.com/products/rrs/ ),
it is not free but cheap enough.
Supported drives listed here:
http://a-ff.com/products/rrs/drives/
Best regards
 Post subject:
PostPosted: March 2nd, 2006, 8:15
Can MHDD reset the password of this drive or Unlock it.
Have somebody tried or Know the master password.
My currency is weaker than dollars.
1$ = 60
Faisal
 Post subject:
PostPosted: October 11th, 2006, 11:56
Hi
I have a Fuji MHT2030AT hard drive which is protected, this disk was in a NEC laptop... maybe someone know the NEC's MHT2030AT Master Password ?
There is "hotswap" method like for Xbox for laptop ? :P
 Post subject:
PostPosted: October 11th, 2006, 17:00
Some help for free - works with MHT.
find some program named fujtool ver 0.4 by (c) Konstantin Popov. (2003)
Run DOS drive as primary master.
Plug MHT (and most other fujitsu) to secondary master.
Run Fujtool.exe
Select 3 (secondary master - where MHT is connected.)
Select r (Read)
Select block 12 for master password.
Select r (Read)
Select block 13 for user password.
 Post subject:
PostPosted: October 11th, 2006, 17:02
thanks coffeebean I'll try this tip tomorrow 8)
 Post subject:
PostPosted: October 11th, 2006, 17:05
I have the tool, and I can share it if you need ... I'm going to try it now :o
 Post subject:
PostPosted: October 11th, 2006, 23:36
hi Dude,
Can you mail to to me
bahacevik@yahoo.com
thx.
 Post subject:
PostPosted: October 12th, 2006, 13:17
it's OK ;)
 Post subject:
PostPosted: October 12th, 2006, 14:05
not working for me... i'll try again later...
 Post subject:
PostPosted: October 13th, 2006, 13:38
Can somebody share the tool on the forum MHT
Thanks in advance
 Post subject:
PostPosted: October 13th, 2006, 13:43
i can email you the file... but is not working for me...
Users browsing this forum: ccc and 82 guests
