 Post subject: remove severe badsector
PostPosted: October 16th, 2006, 7:52
I have many hdd with severe badsector (quantum, seagate, fujitsu, maxtor, samsung, HP, WDC, toshiba, hitachi).
I used MHDD, Victoria, LLF, PC3000, but the badsector is remain.
Have someone experienced with the kesender ? (http://www.yec-usa.com) Hardware and software to clip function will mask any uncorrectable bad sectors.
Please share with me, please
thanks
 Post subject:
PostPosted: October 16th, 2006, 13:36
If bad sector's are physical , is the disk to the expulsion .
Regards .
 Post subject:
PostPosted: October 18th, 2006, 14:00
There is a way to remove bad sectors there can be physical bad sectors but there is a way to remove them also there can be some modules curroption . There is a way to remove physical bad sectors add them to plist .
Have u used pc3000 for this purpose if yes what problems were u facing explain in detail i can help u out .
 Post subject:
PostPosted: October 18th, 2006, 23:29
I use PC3000 to remove badsector and I do step by step :
1. erase defect HDD in P-list and G-list
2. formating/LLF HDD
3. logical scanning/PC Defectoscope/rellocate badsector, but the error
message : overload badsector
4. selfscan, but I can`t do selfcan for all HDD, etc : maxtor poker
5. thanks for all reply
 Post subject:
PostPosted: October 20th, 2006, 10:32
Most of the time severe bad sectors occurs due to firmware curruption chk the firmware struture of the drive there may be a curropted module rewrite it then regenerate translator clear glist and plsit .
then chk the surface !!
 Post subject:
PostPosted: October 21st, 2006, 7:40
I am very thanks to rameez & bigolsen for your answer,
But I will know the function of kesender, what the tool can make HDD with severe badsector become no badsector (http://www.yec-usa.com) or its tool better than PC3000 for repair severe badsector.
thanks
 Post subject:
PostPosted: October 21st, 2006, 13:07
How much is this tool ??
Does it solve firmware problems ??
Users browsing this forum: ccc and 164 guests
