 Post subject: Fujitsu MHV2100AH
PostPosted: November 7th, 2006, 23:09
I have a Fujitsu MHV2100AH 2.5" harddrive that was accidentally locked by installing it in another system. The drive has no data on it. Is there a way to wipe the data and remove the password?
MHDD says:
FUJITSU MHV2100AH LBA: 195,371,568 BIOS: 82H
SN:XXXXXXXX FW: 00000096 Cache:8192KB
Supports: HPA AAM DLMC LBA MS16 DMA (UDMA5, MWDMA2)
SMART: Disabled Selftest: Supported Errorlog: Supported
SECURITY: HIGH, ON Size=95396
WARNING: THIS DRIVE IS LOCKED BY ATA PASSWORD
Thanks.
 Post subject: You need professional
PostPosted: November 8th, 2006, 2:11
you need professional tools PC3000 or you can have cheaper alternative like
http://www.hdd-tools.com/products/rrs/
go for cheaper in your case.
DF 8)
 Post subject: Re: Fujitsu MHV2100AH
PostPosted: November 8th, 2006, 10:07
MHDD says:
Thanks.
wipe no remove ata password ...
Нет ничего невозможного
 Post subject:
PostPosted: November 8th, 2006, 12:44
Security erase with master pwd?
 Post subject:
PostPosted: November 8th, 2006, 15:11
Can I use MHDD to issue the security erase command? I think I know the master Pwd, it should be 32 spaces.
 Post subject:
PostPosted: November 8th, 2006, 19:23
I don't see an imediate command U could use in MHDD, however in some older versions there is a scripting engine U can use for this purpose.
Or maybe the fasterase command.
 Post subject: re
PostPosted: November 8th, 2006, 19:52
See here: http://www.rockbox.org/lock.html
 Post subject:
PostPosted: November 9th, 2006, 9:47
if u think u know the master pwd for the hdd then unlock it using mhdd .
 Post subject:
if u think u know the master pwd for the hdd then try unlocking it using mhdd .
 Post subject:
PostPosted: November 9th, 2006, 15:19
You can get it unlocked remotely here: http://www.hddunlock.com/
Good luck
Users browsing this forum: Google [Bot] and 86 guests
