 Post subject: How work victoria for windows
PostPosted: November 29th, 2006, 6:15
Please
i don't know
thanks
 Post subject:
PostPosted: December 1st, 2006, 8:48
Seems to be the Victoria for windows does NOT works unless you have got a russian version of windows.......
 Post subject: re
PostPosted: December 1st, 2006, 10:24
Here is a version in english.
http://www.mytempdir.com/1092261
 Post subject: vicrtoria for windows
PostPosted: December 1st, 2006, 10:34
Hi!!
There's no doubt victoria for windows has english interface, BTW this beta version 4.0, seems NOT be working on occidental version of Windows XP.
In other way: is not a language problem, but seems a OS problem.
BTW, does it work for you?
 Post subject: re
PostPosted: December 1st, 2006, 10:41
I have XP-SP2 and the program work !
Copy *.ini file from : http://forum.hddguru.com/victoria-4-for ... t6457.html
 Post subject: replay
PostPosted: December 1st, 2006, 11:10
I have used victoria for windows on windows 98 se
and works but the primari is locked
 Post subject: re
PostPosted: December 1st, 2006, 11:24
Copy *.ini !!!! I have enable primary, no problem. Write in PM and I send a capture screen with primary master job.
 Post subject: here
PostPosted: December 1st, 2006, 11:27
You can see a capture screen:
http://www.mytempdir.com/1093513
 Post subject:
PostPosted: December 1st, 2006, 20:49
danrevella
Bugs fixed, Version 4.1
http://hdd-911.com/index.php?option=com ... cdesc=DESC
 Post subject:
PostPosted: December 1st, 2006, 21:07
Hi!!
many thanks!!!
I have added in ata section:
Enable PM=1
BTW it still tell me that the port is locked, no other privileged and date error, I have to try on other computer, coz on this I only have got hd on the primary port......
 Post subject:
PostPosted: December 1st, 2006, 22:01
Hi again!!
Just try with 4 different computer..... (my wife will kill me this time.... ;-))
Only on 1 computer it works, on the other always tell me that the primary port is locked, even if the ini file is always the same.....
Not now, but tomorrow I'll try with BartPE cd, and I'll let you know!!!
 Post subject:
PostPosted: December 2nd, 2006, 6:20
danrevella
Forbidden to test system drive via i/o ports! Or the information will die, or all will hang.
 Post subject: How to take Image in windows version
PostPosted: December 2nd, 2006, 12:59
In dos we could take PIO to image. But how to take in windows. Can any one explain it
DS
Users browsing this forum: No registered users and 127 guests
cron
