 Post subject: mAXTOR 6Y080P0
PostPosted: December 3rd, 2006, 13:40
6Y080P0422811-YAR41BW0-NMBA-M8FYA
Accidentaly i killed this drive :oops: CALYPSO =0MB
but i have the modules
can somebody help me out with correct loader ?
thank you.
VL
 Post subject:
PostPosted: December 5th, 2006, 14:52
Repair of the drive depends on what you did to kill the drive! Can you tell me more?
 Post subject:
PostPosted: December 5th, 2006, 14:59
What you made to kill hdd?
:lol:
Нет ничего невозможного
 Post subject:
PostPosted: December 6th, 2006, 16:20
First i saved all the modules, and modul groups.
Then written some .bad modules. After power cycle or hdd swap identified itself as 6Y084L2 YAR41BZ of YCR41?? dont remember exactly. Now it is only CALIPSO 0MB, and refuses to load modules after LDR. I found only 6Y080P0422611-YAR41BW0-NMBA-M6FYA instead of 8, i dont know is this important difference. I did not tried yet the safe mode, becouse was busy...
this is from saved modules
Family :Calypso
Name :DiamondMax Plus 9
Model :6Y080P0422811C
Model 1 :6Y080P2
Code FW :YAR41BW0
Serial :Y2GY49VE
Ata :ATA/133 HDD
LBA :160086528
Date (Time) :17.4.2004 (18:11)
Alphabetic value :NMBA
PCBA Pn. IDE Label :M8FYA
PCBA Config :28A
Unique :11A
HDA Module :42A
PGT :PGT CAL3.28 F4
Cod :995
None :K118
+5V :670
+12V :960
Ver. Module :Q8.39
File Name :05E40100.RPM
Code FW :YAR41BWZ
Check sum ROM :247A
Status :Program A - Main
File Name :0E840100.RPM
Code FW :YAR41BWZ
Check sum ROM :431B
Specification :version 7.0
hda_sn :Y2GY49VE
media_ven :M
motor_ven :B
pcba_config :Y28A
head_ven :N
hda_module :FY42A
preamp_ven :K
hsa_cfg :W
hsa_sn :2YNBKW3CDMBNU
dealloc_hds :0
hda_stat :NB
motor_label :MKGCWBBXX4154R
cnv_mtr_ven :B
media_label :D57094MV0PZ3P4
cnv_med_ven :M
act_stat :NB
cnv_hd_ven :N
stw_stat :0
pcba_stat :NB
pcba_pn :M8FYA
pcba_sn :MACGQDZE
vcm_label :XB4BP413
hsa_exp :0
awa_cnt :0
stw_sw_rev :LC102.MA
strk_count :0
tpi_mult :0
test_status :0
[/quote]
 Post subject:
PostPosted: December 6th, 2006, 17:27
Hi vlaszlo,
Why you ask for something you already have?
Code FW :YAR41BWZ
Check sum ROM :247A
DataRecovery.bg
 Post subject:
PostPosted: December 8th, 2006, 10:24
if u load the hdd with bad LDR without safe mode u can damage the hdd SA try loading the hdd with LDR in safe mode then try writing the modules .
 Post subject:
PostPosted: December 9th, 2006, 12:18
Samo wrote:
Hi vlaszlo,
Code FW :YAR41BWZ
Check sum ROM :247A
Becouse some modules are damaged, and i am lost. Want to compare it to good modules. The HDD is working again with original modules ( after playing in safe mode ) but cant tranfer G-list into P-list.
With M6FYA modules P-list is working, but seems that only 1 head is reading correctly. So, i did pretty drastic things with SA but i'm a beginner :oops:
thank you for your help
VL
 Post subject:
PostPosted: December 11th, 2006, 16:34
What about Translator regeneration? (Not in Safe, and with born modules)
DataRecovery.bg
 Post subject:
PostPosted: December 11th, 2006, 18:19
I suggest that you read my thread here
http://forum.hddguru.com/maxline-iii-pr ... t6517.html
as I had my drive show up as SABRE 0GB as well and it was due to an incorrect firmware flash.
