 Post subject: Maxtor problem ¿ROM - Over - Other? Help
PostPosted: January 4th, 2007, 0:15
I have a problem with a maxtor 6E020l0 this is recognized like 6E040L1.
The firmware test is Ok. Defect list is clear not data.
When seeing the modules in format hex I have noticed that everything are modified with these data 6e040L1 but the serial is recognized.
When initiating pc3000 and checking structure of firmware this good but when placing information does not leave the model.
I suspect that they can be the ROM with overl but they estan well.
Please help me,
 Post subject:
PostPosted: January 4th, 2007, 10:30
Maybe you "fixed" module 1F - DISK or the drive is in alternative SA.
What's the firmware version it shows?
 Post subject:
PostPosted: January 4th, 2007, 13:20
What size is the hdd reporting bcz 6e020lo is 20 gb and 6e040l1 is 40 gb .
 Post subject:
PostPosted: January 4th, 2007, 14:04
The size 38.29 GB and Firmware NCR31UU0
 Post subject:
PostPosted: January 4th, 2007, 16:40
Online
Drive in alt-SA, this means - main SA is bad
You have to fix main SA
 Post subject: hi
PostPosted: January 4th, 2007, 18:09
1. set jumper safe mode
2. load LDR file
3. repair module UCM dcm and G-list and p-list
 Post subject:
PostPosted: January 6th, 2007, 14:38
I dont think this is a problem with the modules bcz the size has changed 6e020l0 is 20gb how can this drive show 40 gb rewrite the drive id module to fix this issue if this doesnot work then rewrite the correct ROM that will fix the problem alright but be carefull if u rewrite the wrong module then kill r drive .
 Post subject:
PostPosted: January 7th, 2007, 0:16
Online
If you don't understand the problem - don't give the solution, because you wrong
 Post subject:
PostPosted: January 7th, 2007, 4:16
Then tell me whats the solution if i didnot understand the problem bcz i am 100% sure that 6e020l0 is 20gb and size is stored in the ROM according to what i know .
 Post subject:
PostPosted: January 7th, 2007, 11:37
Online
If you read this topic carefully - you can get the problem
I already described the problem
BTW a Maxtor drive size doesn't store in ROM
 Post subject:
PostPosted: January 7th, 2007, 13:58
For my knowledge can u tell me where does the maxtor drive store its capacity .
 Post subject:
PostPosted: January 7th, 2007, 16:37
Online
Actual capacity is storing in module 1F
Zone tables for this kind of drives(N40P) are storing in overlays, but select with module 1F as well.
Users browsing this forum: melvin and 51 guests
