 Post subject: ST3160812A problem
PostPosted: January 5th, 2007, 15:17
Hi Guru`s
I am from Germany ,my english is not so good.More speaking as writing.
I have know of microcontrollerprogramming,assembler..
I want prepare a new hd for xbox to use, my first one goes 100%,and these not.
IT is maximum Locked, because i have make me a terminal-cable, it works 100%, the hd answers.
The seagate documents will me not help, i don`t know what he does.
Data erase its no problem, the hd was new.
When i can read the sector of 32-Byte Passwort ,or Overwrite iàm Lucky.
(with command & Level)
Thank you
Iàm & ST is online for Requests
bye Bernd
 Post subject: boot
PostPosted: January 5th, 2007, 15:51
Interface task reset
4096k x 16 SDRAM
TONKA2 - 1_Disk M-31 12-07-05 09:13
Head Mask FFFF - Switch to full int.
Spin Ready
(P)PATA Reset
Slave
 Post subject: Re: boot
PostPosted: January 8th, 2007, 19:07
4096k x 16 SDRAM
Spin Ready
(P)PATA Reset
Slave
Security Erase Prepare
Security Format Unit
Password
In hex > Seagate (Followed by 0x20h until 32 bytes)
A man is as old as he feels, and a woman as old as she looks
 Post subject: nothing...
PostPosted: January 9th, 2007, 5:33
with atapwd (dos):
ERROR: command requestet by drive
in diagterminal:
T>Interface task reset
4096k x 16 SDRAM
Buzz - Head Mask FFFF - Switch to full int.
Spin Ready
(P)PATA Reset
Master
T>Security Erase Prepare
Command Inactive - No VALID Cert Code Detected
T>Security Format Unit
T>Password
with "strg+R"
T>(VALID Cert Disk Code Detected - Revision # .08G
After reboot, with Type passwort, it says
T>password
HDAless Enabled
T>
Today, i have testet the service from A-FF Repair station... not unlocked...
Can I not the sector erase directly, or disable the PW in the Diag Terminal ?
 Post subject: Re: nothing...
PostPosted: January 9th, 2007, 7:20
Hmmm I should be more specific.
First read ATA Spec (PDF/DOC)
Then you need send commands VIA I/O PPRT (PATA/SATA)
Using ATAPWD... never used it.. But you will need to know what 0x20h is in ascii if you want to use that software
ckw wrote:
with atapwd (dos):
in diagterminal:
4096k x 16 SDRAM
Spin Ready
(P)PATA Reset
Master
T>Password
with "strg+R"
T>password
HDAless Enabled
T>
PostPosted: January 9th, 2007, 7:24
In ATAPSWD .... need
Seagate_______________
"_"=SPACE BAR up until 32 bytes
Users browsing this forum: Google [Bot], skinbob and 113 guests
