 Post subject: victoria 4 for windows
PostPosted: November 22nd, 2006, 19:13
hi!
vcr32.ini:
[ATA Port]
PM=1 >>>>>>>>>>>>>
Channel=1
CustomBase=64512
CustomAlt=56320
Remember Primary=1
I have added pm=1 but victoria always tell me that primary port is locked!!
Any help?
 Post subject:
PostPosted: November 23rd, 2006, 12:26
Enable PM=1
 Post subject:
PostPosted: November 23rd, 2006, 15:06
ditto!!
Enable PM=1
BTW it does NOT works?????
 Post subject:
PostPosted: November 23rd, 2006, 19:32
danrevella wrote:
ditto!!
Enable PM=1
Checkbox 'only non-destructive functions' must be unchecked.
 Post subject: victoria 4.0
PostPosted: November 24th, 2006, 5:00
ditto!!
Many thanks, BTW it does NOT works!!!
 Post subject:
PostPosted: November 25th, 2006, 13:57
Which system u r using .
 Post subject:
PostPosted: November 25th, 2006, 15:33
windows xp pro sp2 on 4 different computer ........
 Post subject: re
PostPosted: December 1st, 2006, 10:28
Here it's *.ini
BinToFile=0
Only EC=0
+reset=0
AllDev=0
AltStat=1
TermoCtrl=1
HPA Tmp=0
HPA Mb=0
[Hint]
Hints=0
[SMART Checkboxes]
SaveBIN=1
[ATA Port]
Enable PM=1
Channel=1
CustomBase=54272
CustomAlt=55298
Remember Primary=1
[Seek]
Method=0
Timeout=100
[Security]
Method=1
Level=0
Password=password
 Post subject:
PostPosted: December 1st, 2006, 10:50
Thanks for the ini, but the problem is that I always get "Error Privileged instruction" in every function I try to use.....
 Post subject: re
PostPosted: December 1st, 2006, 11:21
I have a capture screen but I can't uploaded in this Forum , maybe in PM.
Download this version(with porttalk included) and try.
http://www.mytempdir.com/1092261
 Post subject: re
PostPosted: December 1st, 2006, 11:28
here it's a capture screen with primary master enable:
http://www.mytempdir.com/1093513
 Post subject:
PostPosted: December 1st, 2006, 13:32
I talked with author and he said - this is a local time format problem
He uses TimeToStr function with another time format (like in Russia)
He fixed it but still does not release new version
BTW you can ask author (Ruterian) a question through PM
 Post subject:
PostPosted: December 1st, 2006, 15:04
This is avery good news!!!
Many thanks!!!
 Post subject: PIO To File
PostPosted: December 3rd, 2006, 5:01
In dos we could take PIO to image. But how to take in windows. Can any one explain it
DS
 Post subject:
PostPosted: December 3rd, 2006, 9:39
Victoria 4.1 now works wery well, btw to obtain the maximum from this program I hope a BartPE plugin really need.
I try by myself, but with no result.
The advantage of running Victoria under BartPE environment:
-) you may gain full access to all HD: windows is loaded from cdrom
-) there will NOT be other background process that always runs in windows even if we even don't know they.....
-) results will NOT be falsed by I/O slowdown time relatiding to windows program/service running in background.
-) will be possible to repair a primary hd who fails even in loading windows...
 Post subject: Tnaks
PostPosted: January 19th, 2007, 0:34
Nice, i don't knew about victoria, thanks
Users browsing this forum: No registered users and 115 guests
