 Post subject: newb help and info
PostPosted: January 15th, 2007, 19:11
Hi to all.
since im new in this i need some help.
i heave a maxtor diamondmax plus 9 160gb sata drive withserial/calipso/p11/therm board. in fact i head 2 of them. one gead working mechanic part other head good electronigs. so i heave excanged elegtronics board on drives. after that drive is reckognised ok but i get smart errors in windows (drive failing....).
is there some way to recalibrate drive using mhdd or other software? i heave tried to find some clue on how to do it using mhdd but could not find it.
thx in advance
 Post subject:
PostPosted: January 18th, 2007, 12:43
Just back up your data and dont use the drive if u r willing to use the drive then clear the glist with pc3000 or any other software that u may have the drive will then work fine .
 Post subject:
PostPosted: January 19th, 2007, 2:50
After Clear G-list Drive will Works fine? :shock:
 Post subject:
PostPosted: January 21st, 2007, 4:52
yes the drive works fine after u clear G-list there is no effect on the drive's performance .
 Post subject:
PostPosted: January 22nd, 2007, 4:41
do you know what are you saying..?
if (G-list=clear)
drive will not work fine}
else
you are making Fool of newbies
else
you don't Know about hard drive
End
Run this you got error.
Thanks :D
 Post subject:
PostPosted: January 23rd, 2007, 14:23
yes i am pretty shore that the drive runs fine after u clear the G-list because i have done it hundreds of time transfer defects from glist to plist then clear glist .
One more thing i said
THE DRIVE WILL WORK FINE AFTER U CLEAR GLIST
 Post subject:
PostPosted: January 24th, 2007, 2:32
friend ,do you know what is G-list and what is P-list?
how they works..? what happen when you change P-list and what happens if you clear any of defect list..?
how modules depends on each others.?
as you answer its seem you don,t want study on drive and just throughing ideas without knowing what happend after that..
Sorry i have not so much time to make you understand..that you are wrong..So i kindly request you to not to throughing the ideas without a year of research on it.Better way to learn is to read document ..read modules combinations ..Try to understand how drives work, learn all post by experienced guys..
BTW Please don,t Reply and tell me what you do and what you learn yet..
because you post explains all..what you learn and what you know.
Rameez,friend that all i write here is not to disobey you and i not willing to hurt you.I just willing to Help as friend.Maybe you don,t need help,So ignore what i write here.
Thanks & Regards :D
Users browsing this forum: Google [Bot] and 280 guests
