 Post subject: Problem HDD SP802N
PostPosted: January 26th, 2007, 8:10
Hi to all
HDD SAMSUNG SP0802N FW: TK200-04
IN MHDD NO READ SN:
It beats eight times and it disconnect (off)
Help
:roll:
Нет ничего невозможного
 Post subject:
PostPosted: January 27th, 2007, 1:09
Seems as Broken Head Problem.
what is LED code?
 Post subject: Thanks!!
PostPosted: January 31st, 2007, 14:43
what is LED code?
THANKS my friend!!
:wink:
 Post subject: HEAD problem
PostPosted: January 31st, 2007, 14:48
Hi to all!
How will donor of head identify a hd for this model?
:oops:
 Post subject: Re: HEAD problem
PostPosted: February 7th, 2007, 12:38
sempre wrote:
Hi to all!
:oops:
how will it find compatible heads for this model?
there is the question!
:roll:
 Post subject:
PostPosted: February 7th, 2007, 12:58
You need another of the same model, and the country has to match. Although that should be a fairly simple one.
 Post subject: Odiferous
PostPosted: February 7th, 2007, 16:56
Thanks for help!
Is he only the country and the model?
The firmware also?
:roll:
:idea:
 Post subject:
PostPosted: February 7th, 2007, 17:23
P/V must match, and U may run into head alignment problems as well.
