 Post subject: Selfscan problem
PostPosted: February 11th, 2007, 7:12
I did a selfscan on Maxtor 2b020h1 dsp drive it took about 8 hours i connected it to a external power supply with LED connected for monitoring after 8 hours the led switched off then i connected the drive to victoria for scanning its model changed to 2b010h1 and capacity changed from 20gb to 10gb and the surface was full of bad sectors what should i do .
Thanks in advance .
 Post subject: Re: Selfscan problem
PostPosted: February 11th, 2007, 17:06
Thanks in advance .
Clear defect tables, and start again.
DataRecovery.bg
 Post subject:
PostPosted: February 16th, 2007, 3:28
Thanks i will do that .
Can selfscan fix damaged overlays ?
Users browsing this forum: Google [Bot] and 83 guests
