 Post subject: Maxtor Nebula detected at startup and 15 sec head clicking
PostPosted: February 13th, 2007, 19:27
Hi! Got a drive from a friend that does not work anymore. Looks like firmware problem but I also have clicking head noise also.
(same thing..? )
maxtor 51536h2
Diamondmax 45 plus
15.3gigs
firmware JAC61HU0
logic board nebula 301334101
Manufactured in 2000
In the bios, in auto detect, detect nothing.
I write the cylinder/head manually in Bios, same problem.
At startup, the drive is reported as Maxtor Nebula but is not recognized in Dos or Windows.
When power is on (and this is the same with IDE cable unplugged), the drive spins, and start clicking about 2 times per seconds, going to about 3 times per seconds after 5 seconds. The clicking stops at 15 seconds. If Windows continue to download, eventually the computer reboots.
So basically what should I tell my friend about his options? Seems like recovery from firmware could be possible but it seems like from what I'm reading that the majority of people don't get the heads clicking if firmware is the problem though it might be what this model does..?
Many thanks!
Stephen
 Post subject:
PostPosted: February 14th, 2007, 4:16
HI Stephen,
what's the firmware version shown in MHDD(or any other tool you use) after drive stop click?
Is it JAC61HUZ or something else?
DataRecovery.bg
 Post subject:
PostPosted: February 14th, 2007, 9:46
Yes, it is JAC63MQZ
That is all I can get though, the program says it cannot do anything because there is no LBA infos that it can find on the drive...
Stephen
 Post subject:
PostPosted: February 14th, 2007, 11:18
I can't be 100% sure but seens to me, that your drive have a headache :(
You should take it to data recovery company.
DataRecovery.bg
 Post subject:
PostPosted: February 15th, 2007, 11:20
Yeah, and my Western digital is clicking when I started the pc this morning... :shock:
Time to transfer the stuff. After restarting the pc 3 times, everything is working fine...
Stephen
 Post subject:
PostPosted: February 16th, 2007, 3:39
The firmware of ur drive is damaged u need to fix that first then u will get ur data .
 Post subject:
PostPosted: February 16th, 2007, 10:24
Understood, will forward that to my friend. Thanks!
Stephen
Users browsing this forum: Google [Bot] and 282 guests
