 Post subject: Maxtor N40P Diamondmax plus 8 Need Data
PostPosted: February 17th, 2007, 14:16
Hello to all Respected Sir's
I have a Maxtor Hard disk
On Top Cover: 6E040L051623 (Diamondmax Plus 8)
AAA
Code...................NAR61590
K,M,C,A
On PCB B8FEA
But in PC3000 it detects as
Model.......................... Maxtor 6E040L1 (as you can see on cover its 6E040L051 And detection is different)
Firmware....................... NCR31V30 (And in card its diffrent)
Drive status:
Disk detects ok
No error in modules / firmware
have 3 reading error in Zone 9 but i have fixed them
But when i try to access the disk it gives error in all LBA sector I want Data from the disk
Please help me. its urgent
Thanks and Regards
DF
 Post subject:
PostPosted: February 17th, 2007, 14:27
Is the G-list full?
 Post subject: List is Empty
PostPosted: February 17th, 2007, 14:44
pcimage
No if I do G list Reading Its Empty. and Same with Plist Hutil and Plist A_PDL reading.
Thanks for your Prompt reply. If U have any Yahoo msn or ICQ
 Post subject: In victoria
PostPosted: February 17th, 2007, 15:11
In victoria it gives (Failed)
Model : Maxtor 6E040L1
Firmware : NCR31V30
Serial : E1BJZ35E
Disk size : 80293248 LBAs 39205 Mb
CHS: 18415/8/1140 82004 Mb
SMART : Enabled, Errlog, Selftest
CACHE: 2048k; L/A=ON; Wr=ON; ok
Support : LBA, HPA, AAM, APM, DLM, DMAUDMA-6
AAM val : 0 Disabled
APM val : 0 Disabled
Status : *Failed
Spindle : Active
Security : Not supported
 Post subject:
PostPosted: February 17th, 2007, 19:12
darkfroce1
Pay attention to the microprogram
NCR31V30 /NCRxxxxx/ and it should be NAR61590 !
6E040L1
In NCRxxxxx you can't access drive in LBA mode. Usualy NCRxxxxx is used in manufacture process to create NAR61590.
Try in safe with appropriate LDR.
DataRecovery.bg
 Post subject: Thanks Sir
PostPosted: February 18th, 2007, 2:03
Thanks for your prompt reply and correct guidance sir I have accessed the disk in safe mode now it shows the following
HDDs Identivication has been read
1B overlay loading
1C overlay loading
ROM Copy loading
HDD Soft Reset
Overlaies loading
HDD Soft Reset
Ok!
Read roadmap............................ : Ok
Read roadmap extension.................. : Ok
Read zone allocation table.............. : Ok
Read Technological ID................... : Ok
Read Zone allocation table extension.... : Ok
SA head................................. : 3
Ext Model............................... : 6E040L0510623C
HDD has an alternate service area
HDD structures have been read successfully
Module : 78............................. : UBA 24 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 352/3/24
Now When I Read the G LIst . I can See the Defects
RZTBL having read error
RZTbl
UBA 18637 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 386/3/279
787 in P list
52 in Glist
There is error in RZTBL both in Copy0 and Copy1
now how to make drive access the drive in normal mode
DF
 Post subject: Please Reply
PostPosted: February 18th, 2007, 6:38
Please relpy
 Post subject:
PostPosted: February 18th, 2007, 6:51
Rewrite the Rztbl module #78 in safe mode then access the drive in normal mode i think that will fix the problem mentioned above .
 Post subject: Data Integrity
PostPosted: February 18th, 2007, 9:12
Thanks Sir
But will it effect the data integrity as both copy0 and copy1 are having same problem. so can I copy Module from another Hard disk or Data base (same firmware and model)
 Post subject:
PostPosted: February 18th, 2007, 10:03
yes if u need to save the data then rewrite the bad module from a good one but from the compatible firmware .
 Post subject:
PostPosted: February 18th, 2007, 12:44
Full data recovered.
What I did.
I backuped all the modules both copy 0 and copy1 as there was error in copy0 SA and some on copy1.
I created the LDR from the hard disk. and done SA verification along with reassign bad sector by writing. And Bingo 8) . Disk started ok recognized itself correctly along with Code.
and all wanted data recovered.
Thanks to all the respected gugu's
DF
 Post subject:
PostPosted: February 21st, 2007, 23:16
I have similar problem with that drive DATA, Copy 1 error.
DF:
What I did.
I created the LDR from the hard disk. Which hdd ? faulty one?
what do you mean? Could you please explain more?
DF could you please tell me step by step ?
Thank you all
 Post subject: What I did
PostPosted: February 22nd, 2007, 1:19
Hi
Dear if you have noticed in my case hard disk was detecting faulty with another factory firmware instead of what it should be.so what I did
But I did all these in the guidance of the Hddguru's. I request you to put your problem in forum prior to doing all theses things. as case may be same and case may be vary. Batter take advice.
1 Make drive detect in Safe mode.
2 Entered in the utility through another LDR of same model.
3 Created the LDR file from the hard disk.
4 Re-entered the utility through its own LDR now disk was detecting correctly . Backup ed all the modules copy0 and copy1, in my case copy0 was having error more then the copy1 Plist , glist of copy1 were ok so was bit relaxed.
5 Then I did SA verification with the option Reassign bad sector.
6. came out of utility and re entered normally after removing disk from safe mode.
7 Disk got detected correctly along with firmware and I got 100% data
But I did all these in the guidance of the Hddgurus. I request you to put your problem in forum prior to doing all theses things. as case may be same and case may be vary. Batter take advice.
 Post subject:
PostPosted: February 23rd, 2007, 3:29
if u have error in data copy 1 that is the structure module no need to load it with LDR or so get a hdd with same firmware code and copy data copy 1 strucure module from the hdd then write it on ur hdd that will fix the error .
 Post subject:
PostPosted: February 24th, 2007, 6:42
Please think twice before taking this advice.
 Post subject: this will make data loss
PostPosted: February 24th, 2007, 8:17
Yes copying Modules of other hard disk will also change the PList and Glist and this will make data Loss.
DF
 Post subject: Re: Maxtor N40P Diamondmax plus 8 Need Data
PostPosted: October 28th, 2007, 14:01
Hello to all Respected Gurus
I have a 20GB Maxtor Hard disk
On Top Cover: 6E020L051605 (Diamondmax Plus 8)
ATA/133 HDD
But in my PC-compaq D530- it detects as Model...Maxtor N40P (as you can see on cover its 6E020L051605 And detection is different) in the BIOS when the system is booting
Also,the BIOS detects the HDD as 0.00 MB HDD.
Upon booting,the O.S -win xp couldn't detect the drive
Firmware....................... NAR63G4Z
This symptom started when i fixed the virus issue on the HDD
I want very importantant data from the disk
Thanks in advance
PostPosted: October 28th, 2007, 14:28
Most of the times when hdd shows 0mb its a head issue take the drive out of the computer and check if its making clicking noises or not .
PostPosted: October 29th, 2007, 4:38
Case closed client dont need the data
thanks for support
DF :)
DF :)
www.datatracksystem.net
PostPosted: October 29th, 2007, 10:11
ATA/133 HDD
If the drive doesn't click or beep then most likely it's a firmware corruption.
You need to find someone who can work with drive firmware.
Where are you located?
Users browsing this forum: No registered users and 221 guests
