 Post subject: Travelstar "Excessive Shock"
PostPosted: February 27th, 2007, 15:26
Hi, I have several 2.5' ibm hds have the following problem:
Tested to have no bad or slow sector using MHDD. But when using DFT run the advanced test, just pop up: Failure Code:0x73 -Defective Device, Excessive Shock. I use PCI pc3000 run format and erase SMART, the problem still exist. And I also try to install OS on the drive, it seems to work just okay.
Have anyone encounter similar problem? Any solution? Thanks.
 Post subject:
PostPosted: February 27th, 2007, 16:58
Drive was dropped
you cannot fix it
 Post subject:
PostPosted: February 27th, 2007, 17:08
Good for spare parts, that's it.
 Post subject:
PostPosted: February 27th, 2007, 18:48
Doomer wrote:
Drive was dropped
you cannot fix it
Shock sensor replace?
DataRecovery.bg
 Post subject:
PostPosted: February 27th, 2007, 20:31
Samo wrote:
Doomer wrote:
Drive was dropped
you cannot fix it
Inside the HDA?
then U are at the same point: can use it for spares :)
 Post subject:
PostPosted: February 27th, 2007, 22:55
Okay. Thanks a lot.
 Post subject:
PostPosted: February 28th, 2007, 6:34
pepe wrote:
Inside the HDA?
:D
DataRecovery.bg
 Post subject:
PostPosted: February 28th, 2007, 11:22
Pepe, are you sure it's inside HDA? Don't know about 2.5 but on 3.5 it always used to be on PCB.
scott, try to swap PCB from a good drive on ATCS or ATDA and see how it goes.
 Post subject:
PostPosted: February 28th, 2007, 13:39
Travelstars have it inside usualy.
 Post subject:
PostPosted: February 28th, 2007, 16:00
Alright, I'll try that later and let you guys know whether that work or not. Thanks for the advise.
 Post subject:
PostPosted: March 22nd, 2007, 21:12
Sorry for the late update. But I run into some other trouble with these drives. It seems swapping PCB didn't work as expeceted. And what's worse, I once forget to unsolder the rom when switch PCB and the cause clicking, what's werid when switching back it still click on the good one. It seems rather risky to me to swap PCB using the PCB from a good drive.
Users browsing this forum: Google [Bot], napalm_atx and 299 guests
