 Post subject: N40p BSY
PostPosted: February 26th, 2007, 12:37
I have many drives that show busy dont go to readiness position stuck on BSY for i tried leaving it for 30 minutes didnot change postion have any ideas as to what is the problem
 Post subject:
PostPosted: February 26th, 2007, 13:02
Any stange noises?
 Post subject:
PostPosted: February 26th, 2007, 15:15
no noises just plain motor sound .
 Post subject:
PostPosted: February 26th, 2007, 16:08
Safe mode->loader->check SA.
 Post subject:
PostPosted: February 26th, 2007, 16:18
OK. Does BIOS see drive properly, or as "N40P"?
 Post subject:
PostPosted: February 27th, 2007, 13:36
no i cant read drive id so i cant chk what it say N40P or the normal id .
I also set the hdd in safe it report readiness then i load the ldr then again stuck on BSY position . What to do now ?
 Post subject: rom
PostPosted: February 27th, 2007, 14:31
may be faulty rom.
df
 Post subject:
PostPosted: February 27th, 2007, 17:10
another PCB?
hot swap?
another loader?
 Post subject:
PostPosted: February 27th, 2007, 18:43
Try other PCB
Cut the comunication chanel as last option with combination of LDR loading
What LDR you use, and have you try with other?
/sorry Starling 8)
DataRecovery.bg
 Post subject:
PostPosted: February 28th, 2007, 0:38
maybe the drive hang on readliness.
try this :
safe mode
firmware start
HDD ID reading
choose loader (overlays only) - must match the ROM
If this Ok, hopefully you can access the SA
 Post subject:
PostPosted: March 1st, 2007, 12:19
Changed the PCB same thing no difference then also changed the Loader no effect still stuck on busy and now i will try loading Overlays and how do i repair faulty ROM .
Users browsing this forum: Google [Bot] and 196 guests
