 Post subject: Fast disk imaging with bad head?
PostPosted: March 1st, 2007, 16:39
Hi, What's the best software for imaging a 160GB disk with a dead/dying head, and lots and lots of bad sectors? (about a quarter dead, in long bursts)
Everything I've tried takes a long time to try every single bad sector, so the imaging takes forever (it will take well over a week, easily). MHDD with it's scan uses Sector Verify to get a quicker test but it looks like the ATOF imaging command doesn't use that before it tries to copy :-(
What can I use to copy good sectors but ignore long runs of bad sectors as quickly as possible?
Thanks for any advice
Paul
 Post subject:
PostPosted: March 1st, 2007, 23:45
try copyr.DMA
 Post subject:
PostPosted: March 2nd, 2007, 1:21
copyr.DMA not support to 160Gb :(
@ Repair_ HDD Recover DATA @
Add: Gác 2 Số 10 Hàng Bè Hà Nội Việt Nam
Đặc biệt: Cứu dữ liệu trong trường hợp ổ cứng chết Cơ.
Website: http://www.repair-hdd.com
Tel : 9177619-9263400
 Post subject:
PostPosted: March 2nd, 2007, 3:22
This message has been erased by moderator. Beware: SalvationData are spammers!
SalvationDATA--Profesionnal Hard drive solution Provider. MSN: sales.laura@salvationdata.com
 Post subject:
PostPosted: March 2nd, 2007, 4:30
DeepSpar Disk Imager, totally brilliant for this, I've often got 99.9% images from dying drives with it, but it's expensive!.
Sean
 Post subject:
PostPosted: March 2nd, 2007, 8:52
For drives with bad or unstable heads you need copy program which could create head-by-head map for copying
you should skip bad head because drive can hang during the access at the head
There are two utilities for this kind of copy - AceLab PC3000+DataExtractor or HRT professional version
 Post subject:
PostPosted: March 2nd, 2007, 11:45
I use a Logicube Sonix
http://www.logicube.com/
I've found it way, way better than any windows- or linux-based cloning utility.
 Post subject:
PostPosted: March 3rd, 2007, 2:53
logicube can't handle bad head, it is good for good hdd cloning.
 Post subject:
PostPosted: March 5th, 2007, 10:49
Check out this topic: http://forum.hddguru.com/cloning-equipm ... t6529.html
Users browsing this forum: Google [Bot] and 57 guests
