 Post subject: Seagate ST3120022A not recognised in BIOS.
PostPosted: March 10th, 2007, 14:36
Hi all,
Got a ST3120022A here that spins up OK and makes what sounds like a calibration noise, but instead of becoming ready, it goes to IDX.
It is not ID'd by PC3000, it stops at "loading ROM".
In Safe Mode, I can get the F prompt, and press R.. It resets OK and gives ROM version etc,
Press "j" and it starts to init, but stops at (P) PATA reset and stops.
Any ideas?
Maybe PCB?
Cheers
Sean
 Post subject: Terminal
PostPosted: March 10th, 2007, 15:43
Hello
Send the log showing by terminal
Best Regards
 Post subject:
PostPosted: March 12th, 2007, 8:23
Sure, here you go..
Regualar mode gives:
Interface task reset
1024k x 16 buffer detected
ALPINE - 1_Disk M.14 01-16-03 11:51
Head Mask 000F - Switch to full int.
Spin Ready
3.06 08-21-03 17:50
(P)PATA Reset
and nothing else.
Safe Mode gives:
F>R
Spin Ready
F>j
3.06 08-21-03 17:50
(P)PATA Reset
And nothing else, just sits there. Cannot press any other command keys.
Not a lot of help?
Cheers
Sean
 Post subject:
PostPosted: March 12th, 2007, 14:07
Any of these?
DataRecovery.bg
 Post subject:
PostPosted: March 13th, 2007, 5:53
Hi!
Thanks for reply!
Here is results of "." ";" and "%" respectively......
F>Pgm=00 Trk=0000B2B4(00000000).0(0).000(000) Zn=00 Err=00 ErCt=0000 Hlth=0000 CHlth=0000 Ntrdy LBA=00000000
F>
Age=00 Type=00 MxCyl=0000E386 MxHd=00 MxSct=280 BSz=0800 TCode=0000
F>
:000000010000 AX " "0000E306-0000E385
F>
Hope you can help!
Sean
 Post subject:
PostPosted: March 13th, 2007, 16:53
Why on F> - ???
DataRecovery.bg
Users browsing this forum: Google [Bot] and 269 guests
