 Post subject: Confusion
PostPosted: March 27th, 2007, 16:21
I have a hdd whose model is 6e030l0 it shows N40P in bios then i put hdd in safe mode and load it with LDR of same checksum it gives "Configuration module loading error" in pc3k isa and then enters the utility then i check modules it shows 1F , 1B and 1C bad i rewrite them all all become ok then i chk SA surface give error in uba of Plist then i rewrite plist module then again chk it give error in uba of Rztbl then i again chk it keeps repairing the module i rewrite and something else becomes bad .
Why is this happening? , i am so confused .
Thanks in advance .
 Post subject:
PostPosted: March 27th, 2007, 16:29
Just a guess but bad RAM?
 Post subject:
PostPosted: March 27th, 2007, 18:09
Bad ROM u mean ?
 Post subject:
PostPosted: March 28th, 2007, 10:56
I think it is SA surface have badsector
 Post subject:
PostPosted: March 28th, 2007, 13:22
rameez wrote:
Bad ROM u mean ?
No, I meant bad RAM (buffer). Corrupting data.
 Post subject:
PostPosted: March 28th, 2007, 17:05
The SA surface have bad sectors anything else to do except rewrite the module that is placed in the bad uba .
 Post subject:
PostPosted: March 31st, 2007, 2:43
Did you try "SA write test" ?
 Post subject:
PostPosted: March 31st, 2007, 14:18
yes it says Displacement=0 .
Users browsing this forum: No registered users and 194 guests
