 Post subject: Athena problem
PostPosted: March 28th, 2007, 17:18
I have Maxtor 2b020h1 show Maxtor Athena
I load a loader to hdd in safe mode .
Then start utility in pc3kisa .
Then i chk SA structure it says Module 1B <Glist> bad .
I rewrite the 1B <Glist module> no errors while writing .
Then i chek the structure again no difference still the same module bad .
how do i repair problem .
Thanks in advance .
 Post subject:
PostPosted: March 28th, 2007, 18:35
surely G list is unique for each drive?
 Post subject:
PostPosted: March 28th, 2007, 18:56
i dont have the same backup of the drive and i need to repair the hdd dont need to recover data what if i write glist from another drive and regenerate translator it helps right .
You are right Spildit that does happen if u right Glist but if u clear glist after writing it then the hdd is in normal position and then i can scan for bad clusters .
Users browsing this forum: Google [Bot] and 257 guests
