 Post subject: jpeg corrupt programs
PostPosted: April 6th, 2007, 6:40
ok i got a hard drive here and all the jpegs are over written or have failed draw
is there any program that is out that can repair these jpegs 100%
thanks
 Post subject: Re: jpeg corrupt programs
PostPosted: April 9th, 2007, 1:54
thanks
I don't think so. Even JPEGRecovery (u can find it !) can't do 100%
 Post subject:
PostPosted: April 10th, 2007, 0:40
No data recovery software can recover over-written data or corrupted data.
So its useless to waste time and money for that.
If you could find any such data recovery software which recovers the over-written data then please let us know.
Thanks..
 Post subject: jpeg, avi and wmv corrupted
PostPosted: May 12th, 2007, 14:04
Hi Guys,
I am having a similar problem, the jpges, avi and wmv files are all there, a total of 40gb of data.
I have detected with hddlife that the hdd is damaged, zero health.
Still, I can access most of the data, would say that 90% is fine.
Problem is, I can backup them with Nero because once it finds a bad file the recording stops.
All I have been able to do so far is to move the data to another partition, what is ok moves what is damaged does not. Problem is, it takes forever!
Any idea on how I can recover the corrupted files? Again, they have not been deleted nor overwritten.
Jpeg recovery did not help.
Norton Disk Doctor 2007 did not help (stucks at 16%).
Handy Recovery and Avi fixer did not help.
If they are not recoverable, how can I save the data that is good, without having to move directory by directory to determine it?
Thanks a lot,
Marc.
 Post subject:
PostPosted: May 12th, 2007, 20:15
Hi if you want to use nero try setting ignore read errors & ignore sector errors. You'd probably be better using ontrack or a software that's made for imaging from damaged disks to get an image from this drive.
I think ST is a sub company of Lucas
 Post subject:
PostPosted: May 14th, 2007, 3:53
Media tools can work really fast with this kind of problems . Why dont u try that ?
 Post subject:
PostPosted: May 14th, 2007, 17:23
Hi Rameez,
Any suggestion for these media tools you mentioned?
Shortscurcuits
Great tip for the Nero, I forgot about this option.
Image files seems to be a good idea too.
Thanks,
Marc.
 Post subject:
PostPosted: May 14th, 2007, 22:39
Media tools is the name of the software Use Rameez's suggestion as he has more experience for data recovery & the software to use.
Users browsing this forum: No registered users and 118 guests
