 Post subject: copyr and a faulty st3250823a. its possible?
PostPosted: April 12th, 2007, 20:34
i have a hdd with maby a spindle problem. not recognized by bios and odd noise when sppining. will copyr perform a copy on it?
 Post subject:
PostPosted: April 13th, 2007, 3:33
Copyr is not the solution for your problem.
 Post subject:
PostPosted: April 13th, 2007, 3:36
does the hdd detect .
 Post subject:
PostPosted: April 13th, 2007, 10:30
it does not detect.
the com terminal says:
Interface task reset
4096k x 16 buffer detected
TONKA - 1_Disk S.00 01-27-05 12:46
Buzz - Interface task reset
Buzz -
what to do next?
 Post subject:
PostPosted: April 13th, 2007, 10:43
Have you tried swapping pcb with compatible one and check terminal report.
 Post subject:
PostPosted: April 13th, 2007, 10:47
not yet. im having trouble findin the correct replace.
i forgot to mention that the hdd gets hot quickly. does that confirm about the spindle problem?. re-oiling would help?
 Post subject:
PostPosted: April 13th, 2007, 11:25
That maybe confirm pcb problem.
So best option is really to find pcb and try it before any other thing.
 Post subject:
PostPosted: April 13th, 2007, 11:35
thanks. ill tryit and post results
 Post subject:
PostPosted: April 13th, 2007, 11:49
Ok.
Users browsing this forum: Majestic-12 [Bot] and 257 guests
