 Post subject: old quantm fireball drives power problems
PostPosted: April 20th, 2007, 0:19
salam alekm
i have hdds quantm with nearly same problem when i give it power just the led is flshing and dosent spin up the voltage that reaches to motor is 3 volt in some and 7 in one i measured it from good one its 8 volt what makes voltage drop in pcb?
 Post subject:
PostPosted: April 22nd, 2007, 6:10
Did you try to swap PCB?
 Post subject:
PostPosted: April 22nd, 2007, 6:59
The quantum fireballs are well known for electrical faults, particularly the Fireball LCT family. PCB replacement sounds like the best thing to do.
 Post subject: i already repaired a pcb
PostPosted: April 22nd, 2007, 9:15
salam alekm
i already repaired a pcb that had burned trans but the other that has no burn has no errors with trans it seems somthing in power circuit please any one has expirence in these tell me
Users browsing this forum: No registered users and 253 guests
