 Post subject: worse than bad sectors
PostPosted: April 22nd, 2007, 6:16
Hi, i found that one my hard drive cluster is completely unaccessable. When i try to read data from there - pc sometimes hangs. When i try to defragment - pc hands for 1s, continues to defragment, hangs for 1s again, continues job and so on... I tried to scan with scanDisk for bad sectors - pc hangs. I did low level format - didnt help. Thanx to O&O defragment tool i know which cluster it is. Is there a way to prevent my hard disc using that cluster?
 Post subject:
PostPosted: April 22nd, 2007, 6:54
I think its time to replace your hard drive. I assume the disk is still visible within BIOS as O&O could identify it. If you require the data It might be worth attempting a clone to a new hard disk with media tools and with a bit of luck it will even boot up.
 Post subject:
PostPosted: April 22nd, 2007, 8:00
it is working fine just several sectors realy screwed up
 Post subject:
PostPosted: April 23rd, 2007, 8:49
i found out that i have 5 bad sectors. physical bad sectors i gues. i tried to remove them with DRevitalize v1.1, fist time it said that i have 5 bad sectors, 1 recovered. i ran it again, again 5 bad sectors and 1 recovered, i ran it one more time - result same. maybe anyone knows better sollution?
 Post subject:
PostPosted: April 23rd, 2007, 9:58
Even if you manage to repair the bad sectors, once your disk has started developing them you will get more bad sectors soon enough.
I do not think repairing the disk is the best option for you
Users browsing this forum: Google [Bot] and 51 guests
