 Post subject: selftest maxtor ares64k problem
PostPosted: April 25th, 2007, 15:14
can help me how to selftest maxtor ares64k, why process stop in step 4 (id 89h) ?
maxtor 2F030J0310211
thank's
 Post subject:
PostPosted: April 25th, 2007, 17:02
id 89h - Power switch
DataRecovery.bg
 Post subject:
PostPosted: April 25th, 2007, 17:20
why dont u run selfscan by saving it to hdd rather then running from the pc3000 hardware .
 Post subject:
PostPosted: April 26th, 2007, 2:29
What are You talking about? What's the point? Could You explain in details please?
Thank You!
DataRecovery.bg
 Post subject:
PostPosted: April 26th, 2007, 3:07
Selfscan can be run i two ways :
1) From the script on the on pc3k pci the hdd must be connected to the hdd for that purpose and for running selfscan from script u should edit id89h and disable it so it doesnot restart .
2) Another method is that u save the selfscan to hdd and disconnect from pc3k pci and connect it to a external power supply u may connect a LED for monitoring it .
 Post subject:
PostPosted: April 26th, 2007, 3:33
But both ways id 89h must be NOP, so what's the point, if Ss have been run immediately or from ID?
DataRecovery.bg
 Post subject:
PostPosted: April 26th, 2007, 14:50
No if u save to hdd u dont have to edit selfscan script .
if u save to hdd then after the step id89h the hdd starts selfscan from the point where it left .
 Post subject:
PostPosted: April 27th, 2007, 3:37
You mean to leave it "as is" with no change at all and save it or?
I really did not understand, why is needed to restart the Ss at all?
DataRecovery.bg
 Post subject:
PostPosted: April 27th, 2007, 13:40
its a factory process that checks that hdd can restart or not and continues process from from where it left or not .
 Post subject:
PostPosted: June 27th, 2007, 18:19
i want script for self test maxtor ares64k, do you have ? (running script)
thank's
 Post subject:
PostPosted: July 1st, 2007, 5:39
give me the firmware for that hdd i will edit and make a selfscan module and give u rewrite those modules and plug it to a external powersupply .
 Post subject:
PostPosted: July 2nd, 2007, 12:03
NOP-SAVE-START
Users browsing this forum: Google [Bot] and 90 guests
