 Post subject: RECOVERY
PostPosted: May 3rd, 2007, 15:10
Hi to all.
Please help recovery file MDF (SQL SERVER).
SIZE FILE IS 6,9 GB
when copying the archive comes this message of error:
error: stream write error
(MHDD)
when sweeping the surface of the record (scan) I found six bad ones
4 (x) = UNC 117,903,809
2 (S) = IDNF 117,440,519 (LBA)
Some tool (software) that it obtains to correct this problem? (file)
Help-me
Нет ничего невозможного
 Post subject:
PostPosted: May 3rd, 2007, 15:23
I suggest image the drive using DE and use "read with no ECC" on the suspect sectors (after all,some data is better than none!)
Then fix the mdf file with..
http://www.officerecovery.com/project/index.htm?submit/
IMHO
Hope this helps
 Post subject:
PostPosted: May 3rd, 2007, 22:03
you could also try spinrite. It might help but is very slow....
I think ST is a sub company of Lucas
 Post subject:
PostPosted: May 4th, 2007, 1:04
pls also try media tool professional
software is very good
Users browsing this forum: Google [Bot] and 276 guests
