 Post subject: Samsung MH0804H problem
PostPosted: May 10th, 2007, 13:36
Hello friends
I have a Samsung (laptop) disk MH0804H which was not detecting . I opened the disk and head was released. Disk detected ok and I stared to clone it. then after 45% of cloning done it again stopped and now it is giving mentioned below error in terminal. In current position head moves on platter knocks and back to latch and disk stops spinning. Need to recover data please advice me how to make it work again.
Spn OK
H: +00000
UF: 1st Gray err
H: +00001
Load
UF: 1st Gray err
H: +00002
Load
UF: 1st Gray err
H: +00003
Load
UF: 1st Gray err
Unload 0002
H: +00000
UF: 1st Gray err
Unload 0002
H: +00001
UF: 1st Gray err
Unload 0002
H: +00002
UF: 1st Gray err
Unload 0002
ENG>SRV> Unload 0000
LED 13
LED 13
LED 13
Thanks and Regards
DF
 Post subject:
PostPosted: May 10th, 2007, 13:52
Sounds like the head has hit the patch where it got stuck before.
And damaged itself.
Need head swap IMHO.
And re-commence image from back, to the front.
 Post subject:
PostPosted: May 10th, 2007, 13:56
Thanks Sean
I have to search for the same model it is very diffucult to find one.
DF
 Post subject:
PostPosted: May 10th, 2007, 14:05
is there problme with head 3 as 0002 have unlacth error
Please correct me if am wrong
DF
 Post subject:
PostPosted: May 11th, 2007, 2:25
Any advice other then head change as not getting doner disk
DF
 Post subject:
PostPosted: May 11th, 2007, 3:04
DF
Not really, if head is broke then it's broke, no s/w can fix this!
Users browsing this forum: Google [Bot] and 314 guests
