 Post subject: SA not writing
PostPosted: May 20th, 2007, 11:43
Banned User
Hello to all ,
I have a hdd its model is 2f040l0 the drive has alot of bad sectors . I check the hdd in normal mode with pc3k isa , i check modules hutil&husr was bad then i try write this module there was an error writing it , after that i chk SA surface error in DATA copy 1&2 Ovl Copy 1&2 . After i write these bad structure module it gives error . The SA writing test was 0 .
I need to repair hdd not recover data i have many hdd with same problem . Please help me . Thanks .
 Post subject:
PostPosted: May 20th, 2007, 12:48
hi!
you don't understand what you are doing.
you should read the manual before killing another drive.
good luck!
Users browsing this forum: No registered users and 47 guests
