Post new topic Reply to topic  [ 34 posts ]  Go to page 1, 2  Next
 Post subject: Need some tips for offloading heads without them touching
PostPosted: May 21st, 2007, 11:53
One issue that I think causes more unrecoverable jobs for me than anything is offloading the heads improperly. Once they are off, I can then put something between the heads to seperate them and allow them to be easily loaded onto the platters. However, some heads seem to be very prone to sticking and therefore damaging the heads, making them useless. Hitachi drives seem to be quite prone to this for some reason.
I was just wondering if anyone out there has a solution that allows you to offload the heads without letting them come in contact with one another? Also, is it just a string of bad luck on my part or are the heads really that fragile that coming in contact with one another will kill them? Also, if the tools are magnetized in anyway, will that cause this sort of problem. It's weird because I can do some swaps like this and they go just fine with no problems, and the heads seem really resilent. However, lately head swaps have been more and more prone to failure. I'm thinking that another possibility may be the fact that my tools are getting magnetized when I'm working with the magnets and such. I had one of the magnets pull a lot of my torx drivers over and ever since then it seems like I've had nothing but problems.
 Post subject:
PostPosted: May 21st, 2007, 16:37
I'd like to know the answer to this too. I just got the video from Salvation, and was disappointed it told all about getting the heads back on the platter, but skipped over keeping the heads from slamming together.
I hate to say it, but I don't think there is a practical way to do it.
 Post subject:
PostPosted: May 24th, 2007, 18:49
There is a very easy way to do it. Cut plastic strips from a blister pack (from a kid's toy or something similar as it has to be medium thick plastic ) and bend it in half. Strip needs to be about 1/4' x 4'. If you don't bend it completely over it can be inserted under the arms of the head assembly before you spin them off the landing area. Hold them in place and spin the platters and move the heads to the outer area, the plastic lifts the heads off the disks and holds them apart at the same time. No scratches and no stuck heads. Will post a pic or two later to help explain.
I think ST is a sub company of Lucas
 Post subject:
PostPosted: May 24th, 2007, 22:23
Wow, I came up with the same procedure as yours, only I use cardboard instead of plastic :)
Works great for me.
 Post subject:
PostPosted: May 25th, 2007, 2:46
I actually tried something similiar, but found on some head stacks the wires hang down a little, and can be damaged by something pushing on the arms.
 Post subject:
PostPosted: May 25th, 2007, 3:01
For Hitachi drives with a head parking ramp, and most notebook drives, there's an even easier method.
I insert a small folded up piece of Anti-Static wrapper (like a mainboard comes in, not the real thin stuff) in between the arms,while the heads are on the ramp.
Then move the heads off the ramp, away from the platter.
Remove the head stack and then do the reverse to replace.
This way the heads never touch each other, and not even the platter!
Practice makes perfect!
 Post subject:
PostPosted: May 25th, 2007, 3:42
u can also use straws .
 Post subject:
PostPosted: May 25th, 2007, 10:08
PCImage, do you mean the pink, thin foam stuff (Like what they use on the MB bottom)? Or the antistatic 'bubble-wrap' stuff? Not the silver bag, right?
 Post subject:
PostPosted: May 25th, 2007, 10:13
The silver bag
 Post subject:
PostPosted: May 26th, 2007, 2:58
For drives with a parking ramp, I use a home-made tool that fastens to both the read/write arm and ramp itself, so I can remove the headstack and ramp together, with no damage whatsoever to the heads - they remain safely parked throughout.
 Post subject:
PostPosted: May 26th, 2007, 10:29
Cool idea. Do you have a picture?
 Post subject: Re: Need some tips for offloading heads without them touching
PostPosted: September 14th, 2007, 2:19
Well, I finally broke down and made one :) It seems to work good, with one exception. When I try to remove or put back the HDA, the arms rub against the edge of the platter (I've been playing with it on a junker drive). I'm worried the head wires might be damaged, or maybe the SA on the platter will get scratched. Has anyone found this a problem? Any way around it?
PostPosted: September 14th, 2007, 5:59
Hi ! use Feeler gauge for automotive, and yes....the plastic one. Not the metal one... :D
My Forum
PostPosted: September 14th, 2007, 10:18
I didn't know they had plastic feeler gauges. Will have to check it out. Thanks!
PostPosted: September 15th, 2007, 18:50
Wow , I use the same as "Odiferous" , one lid and ramp adapter for each generation. As we say "Piece Of Piss" RAMP load drives even with 4-5-6 heads is ok to.
:ookay:
A man is as old as he feels, and a woman as old as she looks
PostPosted: September 15th, 2007, 18:51
It's all in the ANGLE of re-insertion :roll:
PostPosted: September 15th, 2007, 18:57
:ookay:
Hi, a picture of it would be nice 8)
Bosse
http://www.rescue-it.se
PostPosted: September 15th, 2007, 22:34
:ookay:
I can guess what a ramp adaptor is. What's a lid adapter?
PostPosted: September 17th, 2007, 23:33
Well, if anyone's interested, here's my Ramp fixture. All it took was:
Some angle aluminum stock
Drill Press
Files
Sand Paper
Propane Torch
Aluminum 'Welding' rod
6 hours of fitting and filing (I'm a perfectionist)
PostPosted: September 17th, 2007, 23:38
Here's two more pics. Sorry they are blurry, it's my crappy cellphone. Can't focus up close.
I have to admit, I used to be a 'Keep Everything Secret' kind of guy when it came to data recovery. In the scheme of things, helping each other only helps. People in the DR business won't close up shop because you didn't share with them. The average Joe isn't going to do a Head Stack Replacement because they found some info on the Internet. Even if I don't get paid for it, I hope some Grandmother somewhere gets the pictures of her grandkids recovered. I'm thankful that people here share as much as they do.
Users browsing this forum: Google [Bot] and 51 guests
