 Post subject: Strange problem
PostPosted: May 27th, 2007, 5:03
The pcb of my Romulus drive had burned i changed the pcb and checked it on victoria it show ABRT then i load LDR and fix plist mod then regenrate translator . After that i chked hdd it was perfect , after sometime i chk hdd again the head was parking correctly but hdd stuk on busy .
What could be the problem ?
Thanks .
 Post subject:
PostPosted: May 29th, 2007, 22:47
Hi does it stay busy when you use loader?
I think ST is a sub company of Lucas
 Post subject:
PostPosted: June 1st, 2007, 3:31
yes .
 Post subject:
PostPosted: June 2nd, 2007, 8:53
I had a couple like that tried to move full G-list to P-list, was trying to fix them data wasn't needed. I think the p-list was already almost full and now the drives do the same. They were OK until I re-powered the drives. Haven't found a way past this yet :(
 Post subject:
PostPosted: June 3rd, 2007, 5:12
The problem is that i cannot access the drive it is stuk on BSY and doesnot get ready .
Users browsing this forum: No registered users and 64 guests
