 Post subject: 6V160E0 seen as "Sabre2"
PostPosted: May 29th, 2007, 9:39
Hi all!
Any suggestions on this one?
Maxtor DiamonMax 10 - 6V160E0 f/w: VA131610
Spins, calibrates etc, but seen as "Sabre2".
Strongly suspect corrupt f/w, but PC3000 has no support for Sabre2, as of yet.
 Post subject:
PostPosted: May 29th, 2007, 10:08
These drives have often problems with SA
PC3000 UDMA should support these drives
 Post subject:
PostPosted: May 29th, 2007, 11:37
So I understand!
I was kinda looking for a more immediate solution :-(
Does anything support these ****ing drives?
 Post subject:
PostPosted: May 29th, 2007, 13:18
Only self-written-software
I don't know any free or buyable solutions except which I mention above
You cannot build or load loader with old version of PC3000 because it was changed
You need as well special thing to put this device into safe-mode to load loader, so it's kind of hard to do
 Post subject:
PostPosted: May 29th, 2007, 14:10
Well, I'm part of the way there. I got the drive in Safe Mode!
But I guess the only real option I have is Hot Swap and hope for the best!
 Post subject:
PostPosted: May 29th, 2007, 15:09
Probably hot swap would be the only available solution in your case. Even after that you will need to reassemble translator in DE.
 Post subject:
PostPosted: May 29th, 2007, 19:16
Yep, and maybe (but unlikely) file system is FAT32 to make the virtual translator easier!!
Users browsing this forum: Google [Bot] and 41 guests
