 Post subject: Hard Drive / Lag - instability problem PLEASE help.
PostPosted: June 5th, 2007, 17:05
Hi everyone, I hope you can help me avoid a nervous break down as my HD with all my school and work info on it may be dying. I am hoping its windows messing up as usuall. Out of nowhere ive begun to have problems accessing large files on my secondary drive (Seagate ST325082 3AS SCSI). My main drive, the one with windowx xp on it is a segate ST380011A. I dont know to much about hardware but apprently my secandary drive is SATA and my primary one with the OS is not.
Recently every time i try to access large files off my secondary drive, particularly video files, I get an incredible lagging after a while. If its a movie, 10 minutes into ill experience severe lag. This lag ultimatly brings the system to a halt and I need to restart by yanking the plug. I almost seems as if the cache or something starts to choke on too much data. This never happend before/started couple days ago. Does anyone have any idea what could be causing this? Do you feel it is a HARDWARE problem? If so how could i go about backing up this data? I tried to copy a file over from one drive to the other and also experienced lag and eventual system inoperability. Any help would be greatly and i mean grealy appriciated. I have so much going on right now, including a cross country move soon, I really did not need this to add to my troubles.
Again, i appriciate any help you can render, even if its a friendly hug (prefer from a female hehe) )
:arrow: OTHER SYS SPECS:
Asus a78nx delux nforce2 board
 Post subject: UPDATE
PostPosted: June 5th, 2007, 17:41
UPDATE, I scanned drive with HDDScan_v28.zip and got a SMART SELF TEST "error with read element failed" message. Does this mean my drive is dead? The wierd thing is that i am stable to access files and run/play them for a while before the lag/instability problem happens. ALso there is one folder that when i try to access I get a mesage stating that the file/folder is currpt.
 Post subject:
PostPosted: June 5th, 2007, 18:03
Your problem might be caused by a dying head getting unstable as the temperature rises.
What U can do:
1. imediately stop using it, I mean don't power it up and let it go under an OS.
2. I would try to create an image of the drive while giving it some active cooling. This one is also tricky if U have a drive in such condition, I cannot give U good advice here, since U may need some tools to do it.
regards,
[hug] :)
 Post subject:
PostPosted: June 5th, 2007, 18:51
Spildit wrote:
You have a bad head stack and possible platter degradation.
You will need to copy all that you can to a new HDD or DVDs and FAST because i don't think you will be able to read your data any longer.
Everytime that you are trying to access that data you are wasting time that you should be using to backup those files.
Also if you can try to cool the drive with coolers while you are copying the files.
PS -
*Hug*
lol
Ah crap... It wont copy files over to my other HD, it gets stuck in the process and then windows bcomes laggy/unstable. Any ideas? Is this sort of thing repairable? would it cost millions and the use of spys? lol sigh :( Im from portugal too, originally, help out a fellow port in need :( By the way there is a FAN right next to the HD blowing air at it.
 Post subject:
PostPosted: June 5th, 2007, 19:29
Spildit wrote:
You have a PM :)
Are you sure? It says zero messages :o\
Users browsing this forum: Google [Bot] and 73 guests
