 Post subject: Please help....PCB for WD800BB-22jhc0
PostPosted: June 4th, 2007, 20:00
Hi......
I am looking for a PCB for a western digital wd800bb-22jhc0. The DCM is esbantjaa. Any help or advice would be greatly appreciated. Thank you in advance!!!
 Post subject:
PostPosted: June 5th, 2007, 10:44
These new WD drives with L-shaped board have special parameters stored in ROM chip on the board. These parameters are unique for the drive and if you just put identical board from another drive it won't work. All it needs is read this ROM chip from bad board and write it to compatible donor. Only after that it becomes fully compatible and starts to work.
To do that you need to have special equipment like PC3000 or you can try to swap the chip manually if you are comfortable with soldering but in this case you are risking to burn the chip and lose last hope for the data.
 Post subject:
PostPosted: June 5th, 2007, 10:56
So you are saying if the ROM chip is destroyed, then so is the data?
 Post subject:
PostPosted: June 5th, 2007, 11:04
I'm not saying that all data is stored on the chip. It's just if this chip is destroyed you won't get access to the data.
In fact there is a way to restore the ROM chip contents from hard drive System Area in case if original ROM is destroyed but that requires special knowledge and PC3000 and it would be more expensive.
 Post subject:
PostPosted: June 6th, 2007, 3:54
Hi Starling,
Any way you could elaborate on the method of recreating ROM from SA?
I have a WD800BB mammoth with burnt ROM :-(
Cheers
 Post subject:
PostPosted: June 6th, 2007, 9:35
PM. :)
Users browsing this forum: Google [Bot] and 135 guests
