Post new topic Reply to topic  [ 36 posts ]  Go to page 1, 2  Next
 Post subject: technician for a data recovery company
PostPosted: June 6th, 2007, 12:31
Hi i work for a data recovery company, does any1 have any questions?
 Post subject:
PostPosted: June 6th, 2007, 13:01
Yes, how can I recover from a WD800BB (Mammoth Marvel drive) with burnt PCB and ROM?
The answer is eluding me for the moment.
(excluding finding a donor with exact DCM, which is nigh on impossible :-( )
 Post subject:
PostPosted: June 6th, 2007, 13:25
PC IMAGE....I am in the same boat as you. Burnt ROM and bad PCB - can't find a donor, I have been trying for 6 months now.
 Post subject:
PostPosted: June 6th, 2007, 13:32
02yellowgt, your ROM is fine. You just need to transfer it to a donor PCB.
 Post subject:
PostPosted: June 6th, 2007, 13:33
no it isn't.....I had someone try to remove it and broke 2 pins off the IC. Heh....it was a tech. at an electronics manuf. com.
 Post subject:
PostPosted: June 6th, 2007, 13:35
oh, that's bad :(
 Post subject:
PostPosted: June 6th, 2007, 16:11
The drives are easy to find....it's finding one with the EXACT same production numbers to support the bad drive. For example, my drive is WD800BB-22JHC0 and DCM ESBANTJAA. I am no expert (not even close), but it's my understanding that all numbers must match exactly to do a complete PCB swap. Anyone else...agree/disagree?
 Post subject:
PostPosted: June 6th, 2007, 16:22
Thank you VERY much......
 Post subject:
PostPosted: June 6th, 2007, 16:23
If/When you find one please let me know.....
 Post subject:
PostPosted: June 7th, 2007, 2:36
If you'd like to send me the chip, I could most likely repair it for you.
I'm in the UK.
 Post subject:
PostPosted: June 7th, 2007, 4:28
Mine is a WD800BB-00FJA0
DCM: DSBHCTJAH
If anyone can help?
Just a ROM file would be OK, I can burn new ROM from that if necessary
Cheers
 Post subject:
PostPosted: June 7th, 2007, 5:18
replace the pcb with a matching pcb model number found top of pcb near the spindle e.g 2060-701292-000.
NOTE you will need pc3000 to read adaptive information found on small 6 to 8 leg chip and write back to new board. Or simply swap 6 to 8 leg chip near top left of board.
 Post subject:
PostPosted: June 7th, 2007, 5:32
Yes, that is normal procedure! But as I said, the ROM is burnt, so cannot read or transfer :-(
Thanks for the reply though!! :-)
 Post subject:
PostPosted: June 8th, 2007, 3:37
u can also use this
http://forum.hddguru.com/read-write-ser ... t7192.html
for copying data from damaged ROM and copy it to new ROM .
Its really easy to remove and resold ROM as it has eight legs how can someone break one of its legs ?
 Post subject:
PostPosted: June 8th, 2007, 9:47
So, where's that smart guy? He had so many things to tell us... :)
 Post subject:
PostPosted: June 8th, 2007, 14:26
pcimage
Can U read ROM version...?
Pls give ROM (Modules) version...
CHECK_FL
Mikippp
 Post subject:
PostPosted: June 8th, 2007, 15:40
It turned out that ROM was not burnt.
By luck, I tried the original ROM on a PCB from drive with same model, but different p/n of PCB.
Worked 100%
Did not work on PCB from different model, but same PCB p/n
 Post subject:
PostPosted: June 8th, 2007, 16:33
Yea, it's not that easy to smash this eight-legged bug :)
 Post subject:
PostPosted: June 8th, 2007, 16:40
yep, even with smoke coming from the Motor Chip and cooking it!
 Post subject:
PostPosted: June 11th, 2007, 9:18
Maxtors - anyone know what the letters in the four letter code reference?
for ex:
K, M, B, D
or
N, M, B, A and so on..
