 Post subject: Ares Selfscan
PostPosted: June 8th, 2007, 3:51
Hello to all ,
I have many ARES drives 2f040l0/j0 the problem with them is that the hdd is full of bad sectors , low level fomatting also would not help . I checked the SA all modules are ok also SA surface is good . I wasnt able to understand the problem so i copied the orignal modules from the drive made a backup of it and started selfscan on this drives using MRT . It has been two days now still selfscan is running on this drive.
My question is that is there any other way to repair these drives ?
And has someone had sucess with selfscan on ARES drives ?
I have 1000 drives with the same problem any advice would be helpfull .
Thanks .
 Post subject:
PostPosted: June 9th, 2007, 5:35
hi rameez
maybe you need better module group of selfscan for it.
 Post subject:
PostPosted: June 9th, 2007, 17:30
How start selfscan without PC3K?
 Post subject:
PostPosted: June 10th, 2007, 11:50
To wawalab ,
I have started selfscan with editing the orignal modules , so how can i need better modules , i m confused can u please make it a little clear for me .
To gsimon,
I used MRT , besides that u can also use hdd repair .
