 Post subject: Terminal settings for Conner CP2064 for PC3000 Dos
PostPosted: June 8th, 2007, 11:28
I have a defective CP2064; it calibrates and can be detected by the bios, but is not accessible. I would like to connect it to PC3000 for dos to use the terminal, but whatever setting I try, I cannot get a connection.
Unfortunately, the manual has no documentation about how to connect the 2.5" drive to the terminal. Can somebody help ?
Thanks,
Dobre
 Post subject:
PostPosted: June 8th, 2007, 11:48
Dobre, you should have PC3000 PCI, right?
Try to connect it the same way as all other seagates and check the terminal.
 Post subject:
PostPosted: June 8th, 2007, 11:57
I did starling, but i get the message the drive is not supporting LBA and it refuses to continue. :(
Dobre
 Post subject:
PostPosted: June 8th, 2007, 12:05
You can enter Seagate utility with another drive, then power it off, connect your conner and power on to see what it gives you into terminal.
 Post subject:
PostPosted: June 8th, 2007, 13:00
OK, i tried that, but nothing appears in the terminal. With the seagate drive i get the normal messages.
Isn't it possible the conner uses other settings ?
Dobre
 Post subject:
PostPosted: June 8th, 2007, 13:19
I found it.
This question was already posted in russian on iHDD.
http://www.ihdd.ru/forum/conner-cp2064- ... ght=conner
This found i changed the jumpers on the adapter board to:
xx
xx
xx
xx
xx
oox
xxx
xoo
xxx
where oo is jumpered.
Now i get messages in the terminal :D
Dobre
 Post subject:
PostPosted: June 8th, 2007, 13:40
The terminal gives:
Pancho 1.14 03-19-91 Data Lock 021 1 1
Begin test 40
AT
Ref 3A - Xsition1C - Full Spd 06A - Data Lock - Spin ok
Ready
somebody knows what this mean ?
I still cannot access the data.
DE refuses to access the drive since it does not support LBA; not even to make an image.
Any suggestions ?
Dobre
 Post subject:
PostPosted: June 8th, 2007, 16:01
Data Lock?
Maybe some sort of early encryption/password?
The symptoms are similar to a P/W protected drive.
I don't know, only a suggestion?
 Post subject:
PostPosted: June 8th, 2007, 16:08
No, I found out allready that 'Data lock' is normal. Has nothing to do with password.
In the mean time i managed to get the data off the drive with 'very' old software on an even older system.
Regards,
Dobre
 Post subject:
PostPosted: June 8th, 2007, 16:21
Yeah,
some old Pentium 1 machine and Northon Commander probably :)
DataRecovery.bg
 Post subject:
PostPosted: June 8th, 2007, 16:24
Close :lol:
 Post subject:
PostPosted: June 8th, 2007, 16:40
I miss something with that drive, it must have only 2 jumpers located bottom?
The "adaptor board' = ... ?
DataRecovery.bg
 Post subject:
PostPosted: June 8th, 2007, 16:47
Adapter board of PC3000 for 2.5" to ide.
Regards,
Dobre
 Post subject:
PostPosted: June 8th, 2007, 16:58
Ups, my fault I've thought its a 3'5 drive.
DataRecovery.bg
 Post subject:
PostPosted: June 8th, 2007, 17:11
Wow, I didn't even remember Conner made 2.5" drives!
 Post subject:
PostPosted: June 8th, 2007, 17:16
Very Old; 64 MegaBytes :)
And my client needed the data Very Much
Dobre
 Post subject:
PostPosted: June 8th, 2007, 17:41
64Mb?
Wow.
U must have needed a 386/486 based PC to read that load of junk ;-)
 Post subject:
PostPosted: June 11th, 2007, 10:10
This drive probably does not support LBA mode
You have to work in CHS and you have to put proper parameters in BIOS to work with the drive
Terminal message looks OK
 Post subject:
PostPosted: June 11th, 2007, 18:05
Correct Doomer, a recent motherboard bios will not be able to work with the drive. You need chs support.
I've got some very antique stuff here, even a ZX-80.
However, I dont think i will ever get a recovery-job for that one :)
Dobre
 Post subject: Re:
PostPosted: April 7th, 2008, 15:21
cool!!!!!!!!!!!!
10 Print USR 16614,Line,0,90,2,55,28
20 Print "YOOOOOOOOOO!"
Anyway the old Conners are nice to work on,,,Been a few years!
Users browsing this forum: Bing [Bot], Google [Bot] and 87 guests
