 Post subject: MDT
PostPosted: May 29th, 2007, 18:15
Hello Does anyone know MDT TECHNOLOGIES its same physically like WD
This model said MD00400-BABW
But doesnt have DCM, does anyone know if its compatible with Western digial for head exchange´s or need to be MDT factory?
 Post subject:
PostPosted: May 29th, 2007, 19:14
MDT is just refurbished WD drives, I think.
Like Nikimi were refurb Maxtor
 Post subject:
PostPosted: May 29th, 2007, 19:33
Yes they were doing refurbish of WD hard drives, also had some web page http://www.mdt-hdd.com (thats no longer online).
You could use WD for head swap if you have the luck to find the native model of MDT. (Imho)
DataRecovery.bg
 Post subject:
PostPosted: May 29th, 2007, 22:28
Hi I just got a batch of these in last week they say platinum on a plain white label?
Mine are 60-80 & 100GB but the full model shows up in pc3000 such as MDT600BB-00CA0 ect. I'd assume they are either WD rejects or seconds as the P-lists are pretty full. They are identical to the same model WD and the SA is the same so it would be a good bet the heads would be interchangeable too.
I think ST is a sub company of Lucas
 Post subject: MDT
PostPosted: May 30th, 2007, 10:57
Hello Spildit , yes on refurbished Disk they kill the bad heads im get a WD3200KS (320 GB) R think R= Refurbished from january 2007 , just check head map and its only 4 heads enable it and would be 6 Heads , so on my case, MD00400-BABW if i get a donnor for 40GB same preamplifier MHA, would works, if edit the Head map to the full (2 heads) . or what can i do
Thanks all people !!!
:D
 Post subject:
PostPosted: May 30th, 2007, 23:17
Compatible HDA with relevant heads disabled should work
 Post subject:
PostPosted: June 1st, 2007, 3:34
MDT also refurbish Maxtor drives .
 Post subject: WD
PostPosted: June 16th, 2007, 15:57
Hello i find a Donnor for MDT same preamplifier, could work, even donnor has two heads, and patient its two head but one disable on head map??
Thanks to all people
im searching this pcb 2060-001130-012 REVA
from WD800BB-23FJA0 "Mammoth" 3.5 Series does anyone know where can i get
Users browsing this forum: Majestic-12 [Bot] and 222 guests
