 Post subject: Dna0
PostPosted: June 23rd, 2007, 20:13
i have wd hdd itis spindle chip burned L6278 1.7E and R120 itis called at board R69 when i change L6278 1.7E and change R120 it burned again so where is problem
Dms_Corp
 Post subject:
PostPosted: June 23rd, 2007, 20:43
Sounds like a faulty motor which is drawing too much current through the PCB and continually blowing your motor controller chip.
 Post subject:
PostPosted: June 23rd, 2007, 22:32
It might be a frozen spindle too. I have one that burned out the motor chip. When I replaced it, it immediately gets hot. Doesn't get hot when PCB is on another drive...
 Post subject:
PostPosted: June 24th, 2007, 13:36
R69 is located in the -5V DC-DC converter...
If R69 is damaged -> check Q3, U9, L7...
Mikippp
 Post subject:
PostPosted: June 24th, 2007, 17:20
What is U9 IC
 Post subject:
PostPosted: June 26th, 2007, 13:20
U9 is the address of the IC , which is mentioned on the pcb .
