 Post subject: maxtor n40p
PostPosted: July 2nd, 2007, 17:19
GOT 6E040L0 DRIVE WITH TYPICAL PROB... IT REPORTS 6E040L1 AND FIRWARE CODE NAR INSTEAD NAR OTHER MODULES OK HOW TO GET RID OF THESE PROBLEM ANY HELP WILL BE APPRECIATED
 Post subject:
PostPosted: July 3rd, 2007, 0:20
hi HDDTECH:
whats your means for "FIRWARE CODE NAR INSTEAD NAR "??? :shock:
 Post subject:
PostPosted: July 3rd, 2007, 9:46
i mean NCR instead of NAR .......
 Post subject:
PostPosted: July 3rd, 2007, 13:12
PM me i have solution to this probelm .
 Post subject:
PostPosted: July 3rd, 2007, 15:30
into ALT SA.
 Post subject: Re: maxtor n40p
PostPosted: July 11th, 2007, 21:21
What typical problem is that?
I have one for the PC I'm at right now.
PostPosted: July 23rd, 2007, 10:46
try self scan if the drive have altsa (this is the only succesfully method that i know)
PostPosted: July 25th, 2007, 14:47
Banned User
u put hdd in safe mode and load ldr then it will become 6e040l0 then u chk modules, i have solved this type of problems in some hdds of 6e040l0, i got this type of prb when i wrote datacopy1.smb to drive, then its p-list was damaged, then i corrected this
u also chk, it may solve ur problem
PostPosted: July 26th, 2007, 12:09
the problem is in plist rewrite in safe mode with appropriate loader with RAM loaded .
PostPosted: July 26th, 2007, 15:34
Banned User
ya, correct solution, u find the correct ram and ldr for this hdd, first u put hdd in safe mode, load ldr. if plist is damaged then u write RAM and write plist, i hope the problem is solved now.
Users browsing this forum: No registered users and 17 guests
