 Post subject: Quantum LCT15 20.4gb fwr needed
PostPosted: July 3rd, 2007, 14:58
Quantum LCT15 20.4gb fwr needed If any one could help me it would be grat, please send a PM
cheers!
 Post subject:
PostPosted: July 5th, 2007, 2:45
By the way what is the problem with your hdd ? do u need LDR or modules also
 Post subject:
PostPosted: July 6th, 2007, 13:15
Tahnks for the reply!
i need mods and cps, but i have problems with translator and defect list (60h and 61h) both are bad.
Dou know if on lct15 is an other copy of defect list like in others hdds?
cheers!
 Post subject:
PostPosted: July 7th, 2007, 8:05
I don't think there is another copy. U can do the following:
clear the defect list and restore the user area by manually finding shifts.
that's an ugly thing...
 Post subject:
PostPosted: July 8th, 2007, 5:21
Hi Pepe ,
I Read About Shifts .They Happen After Selfscans Mostly .I Do Not Have Much Experience With This Subject .Can You Shed Some Light .Although I Understand The Concept .Live Example Would Be Great
 Post subject:
PostPosted: July 9th, 2007, 14:47
Well,
if U think through the process of the skipping of bad sectors, that is described on several DR related pages, U can easily understand how translator work and understand the borning of shifts when the factory defect list is cleared/modified.
a perfect surface would look like this:
LBA 0 1 2 3 4 5 6 7 8 9 10
in case one sector is detected bad:
LBA 0 1 2 3 x 4 5 6 7 8 9
if U clear the reference for LBA 4 from plist:
LBA 4 will be bad and LBA 5 will be what was LBA 4 previously.
U have to find shift points and correct the image accordingly to have the files contain their previous content.
regards,
Users browsing this forum: Majestic-12 [Bot] and 76 guests
