 Post subject: Pcb compatibility on a faulty Fujitsu Drive
PostPosted: July 3rd, 2007, 12:45
I have a Fujitsu MHU2100AT (2.5") with a faulty logicboard.
What are the criteria for a successful change on those.
The one that I have, has a FW revision: 0BFF8C-00000008.
I know that the same model is a must, but the rest, what is a must? The whole FW number, or just a part of it?
Bosse
 Post subject:
PostPosted: July 3rd, 2007, 13:44
just chek the processor chip that should match with the donor then swap ROM .
 Post subject:
PostPosted: July 3rd, 2007, 13:58
Thanks Rameez,
How can I swap ROM if the board is faulty?
Do you know what is the criteria for swap board?
I have found one with the same model, but with this FW 0BFF5B-00000008
Will that work you think?
Bosse
 Post subject:
PostPosted: July 3rd, 2007, 14:05
If board is faulty it doesnot mean that the ROM is also faulty u can unsolder the ROM from the orignal board and replace it in the donor pcb.
This is neccesary bcz ROM contains adaptive data that is unique for that drive .
 Post subject:
PostPosted: July 3rd, 2007, 14:15
Thanks for the quick reply.
Okey so just change pcb on those drives is not possible, so change pcb and desolder and change ROM will do the trick.
What aboute the donar pcb, is there any restricktion there, or is it just one in the same family (MHU2100AT)?
Bosse
 Post subject:
PostPosted: July 3rd, 2007, 15:11
Just saw the erlier message..
Bosse
 Post subject:
PostPosted: July 3rd, 2007, 16:39
Rameez, just another thought.
How can I determ if the ROM is ok before I desolder the chip.
I have Pc3000 and the drive spinns up, becomes ready, there is no noises from the drive and it don't ID it self.
Bosse
 Post subject:
PostPosted: July 5th, 2007, 2:47
There is no size restricition only the main processor should be the same for swapping ROM . For checking ROM unsolder it and if u have EPROM programmer read its contents using it if it reads then ROM is ok .
 Post subject:
PostPosted: July 5th, 2007, 3:03
Bosse
in this case it is not very probable U are having a PCB problem.
If it was, the drive either would not spin or click very probably.
 Post subject:
PostPosted: July 5th, 2007, 8:31
One real expert once wrote : (Fujitsu)
If ROM is broken - drive will not spin.
 Post subject:
PostPosted: July 5th, 2007, 9:11
it looks like original PCB is good
check SA with PC3000
 Post subject:
PostPosted: July 5th, 2007, 15:04
Thanks for all your input.
Doomer, how can I check the SA, when I can't get the drive to ID....and therefor can't launch the utillity?
I got the 2.27 and it can just handle Fujitsu drives up to MHT...or?
When I start the drive there is the usal small ratteling sound for the drive to become ready.
after that....nothing, just spinns.
Bosse
 Post subject:
PostPosted: July 5th, 2007, 15:52
MHDD can tell you a lot about Fujitsu 2.5".
Give report about bulbs in MHDD when connecting.
 Post subject:
PostPosted: July 5th, 2007, 18:11
Hi coffeebean, the only thing I got in MHDD was "Device not ready".
It looks like this in Pc3000:
Or is it necessary with UDMA in this case?
Bosse
 Post subject:
PostPosted: July 5th, 2007, 19:20
OK,
Connect to MHDD - report on sequence of bulbs on power up.
then report on reset and ID..
btw. MHT and after are very, very quite drives ......
so if you getting some slight clicking then not so good.
Try also your pc3000 pci with universal utility.
 Post subject:
PostPosted: July 6th, 2007, 5:45
Hi there,
I only got: DRSC, DRDY, AMNF, the same on reset (F3) and INIT.
Yep, and this drive is quiet..I have to put my ear against it to hear something at all.
I have done that aswell, and it won't ID it self there either, and when it comes to the menu of drives, this model is not in the list, only in UDMA I guess.
Bosse
 Post subject:
PostPosted: July 6th, 2007, 15:23
I open the drive in pc3000 with the wrong model name, with the intention to just check if it would read the drive....here is the log of it:
Selected family......................... : MHT2xxxAT
Selected model.......................... : MHT2020AT
Model by HDD ID......................... : <HDD ID NOT READ>
Cannot open file C:\Program\ACE Lab\PC-3000\Bin\!Profiles\FUJ25\FUJ_25.STG
Error loading utility options DB.
Loading default settings!
Open the options editing dialog to check and save them
Module table (ROM)...................... : Initializing with default parameters
WARNING! ID = 0104 : Name and RAWName do not match (HS <> Ô)
Loading : HS, head map module......................................... : Error
Error................................................................. : HS, head map module : Name and RAWName do not match (HS <>
Test : Read modules
Test : Read modules
Reading modules to profile folder
Folder: C:\Program\ACE Lab\PC-3000\Bin\!Profiles\FUJ25\MHT\MHU\Data\Modules\
WARNING! ID = 0101 : Name and RAWName do not match (DM <> Ô)
Reading module ID = 0101.............................................. : Ok
WARNING! ID = 0102 : Name and RAWName do not match (PL <> Ô)
Reading module ID = 0102.............................................. : Ok
WARNING! ID = 0103 : Name and RAWName do not match (TS <> Ô)
Reading module ID = 0103.............................................. : Ok
Reading module ID = 0104.............................................. : Ok
WARNING! ID = 0105 : Name and RAWName do not match (FI <> Ô)
Reading module ID = 0105.............................................. : Ok
WARNING! ID = 0106 : Name and RAWName do not match (DT <> Ô)
Reading module ID = 0106.............................................. : Ok
WARNING! ID = 0107 : Name and RAWName do not match (SI <> Ô)
Reading module ID = 0107.............................................. : Ok
WARNING! ID = 0108 : Name and RAWName do not match (SN <> Ô)
Reading module ID = 0108.............................................. : Ok
Reading module ID = 0109.............................................. : Ok
Reading module ID = 010A.............................................. : Ok
Reading module ID = 010B.............................................. : Ok
WARNING! ID = 010C : Name and RAWName do not match (SM <> Ô)
Reading module ID = 010C.............................................. : Ok
WARNING! ID = 010D : Name and RAWName do not match (SU <> Ô)
Reading module ID = 010D.............................................. : Ok
WARNING! ID = 010E : Name and RAWName do not match (CI <> Ô)
Reading module ID = 010E.............................................. : Ok
Reading module ID = 0110.............................................. : Ok
Reading module ID = 0111.............................................. : Ok
Reading module ID = 0112.............................................. : Ok
Reading module ID = 0113.............................................. : Ok
Reading module ID = 0114.............................................. : Ok
Reading module ID = 0115.............................................. : Ok
Reading module ID = 0116.............................................. : Ok
Reading module ID = 0117.............................................. : Ok
Reading module ID = 0118.............................................. : Ok
Reading module ID = 011C.............................................. : Ok
Reading module ID = 011D.............................................. : Ok
Reading module ID = 011E.............................................. : Ok
Reading module ID = 011F.............................................. : Ok
WARNING! ID = 0120 : Name and RAWName do not match (SP <> Ô)
Reading module ID = 0120.............................................. : Ok
WARNING! ID = 0121 : Name and RAWName do not match (VG <> Ô)
Reading module ID = 0121.............................................. : Ok
Reading module ID = 0127.............................................. : Ok
Reading module ID = 0128.............................................. : Ok
Reading module ID = 012A.............................................. : Ok
WARNING! ID = 012D : Name and RAWName do not match (FA <> Ô)
Reading module ID = 012D.............................................. : Ok
Reading module ID = 012E.............................................. : Ok
WARNING! ID = 0130 : Name and RAWName do not match (ZP <> Ô)
Reading module ID = 0130.............................................. : Ok
WARNING! ID = 0131 : Name and RAWName do not match (RE <> Ô)
Reading module ID = 0131.............................................. : Ok
WARNING! ID = 0132 : Name and RAWName do not match (WE <> Ô)
Reading module ID = 0132.............................................. : Ok
Reading module ID = 0135.............................................. : Ok
Reading module ID = 013D.............................................. : Ok
Reading module ID = 013E.............................................. : Ok
Reading module ID = 0141.............................................. : Ok
Reading module ID = 0142.............................................. : Ok
Reading module ID = 0145.............................................. : Ok
Reading module ID = 0150.............................................. : Ok
WARNING! ID = 0151 : Name and RAWName do not match (RE <> Ô)
Reading module ID = 0151.............................................. : Ok
WARNING! ID = 0152 : Name and RAWName do not match (WE <> Ô)
Reading module ID = 0152.............................................. : Ok
WARNING! ID = 0154 : Name and RAWName do not match (FA <> Ô)
Reading module ID = 0154.............................................. : Ok
Reading module ID = 0160.............................................. : Ok
Reading module ID = 0162.............................................. : Ok
Reading module ID = 0163.............................................. : Ok
Reading module ID = 0164.............................................. : Ok
Reading module ID = 0170.............................................. : Ok
WARNING! ID = 0201 : Name and RAWName do not match (DM <> Ô)
Reading module ID = 0201.............................................. : Ok
WARNING! ID = 0204 : Name and RAWName do not match (HS <> Ô)
Reading module ID = 0204.............................................. : Ok
WARNING! ID = 0206 : Name and RAWName do not match (DT <> Ô)
Reading module ID = 0206.............................................. : Ok
WARNING! ID = 0207 : Name and RAWName do not match (SI <> Ô)
Reading module ID = 0207.............................................. : Ok
WARNING! ID = 0208 : Name and RAWName do not match (SN <> Ô)
Reading module ID = 0208.............................................. : Ok
Reading module ID = 0209.............................................. : Ok
Reading module ID = 020A.............................................. : Ok
WARNING! ID = 020C : Name and RAWName do not match (SM <> Ô)
Reading module ID = 020C.............................................. : Ok
WARNING! ID = 020D : Name and RAWName do not match (SU <> Ô)
Reading module ID = 020D.............................................. : Ok
WARNING! ID = 0220 : Name and RAWName do not match (SP <> Ô)
Reading module ID = 0220.............................................. : Ok
Reading module ID = 0227.............................................. : Ok
Reading module ID = 0228.............................................. : Ok
WARNING! ID = 022D : Name and RAWName do not match (FA <> Ô)
Reading module ID = 022D.............................................. : Ok
WARNING! ID = 0231 : Name and RAWName do not match (RE <> Ô)
Reading module ID = 0231.............................................. : Ok
WARNING! ID = 0232 : Name and RAWName do not match (WE <> Ô)
Reading module ID = 0232.............................................. : Ok
Reading module ID = 023D.............................................. : Ok
Reading module ID = 0241.............................................. : Ok
Reading module ID = 0250.............................................. : Ok
WARNING! ID = 0251 : Name and RAWName do not match (RE <> Ô)
Reading module ID = 0251.............................................. : Ok
WARNING! ID = 0252 : Name and RAWName do not match (WE <> Ô)
Reading module ID = 0252.............................................. : Ok
Modules reading process completed
It seems to read the modules okey.
Any suggestions how to get this drive to accept normal (pc3000) commands?
Bosse
 Post subject:
PostPosted: July 9th, 2007, 8:33
Does anyone have any suggestion what might be the problem with this drive?
Any solution is most welcome :P
Bosse
Users browsing this forum: No registered users and 148 guests
