 Post subject: HDDScan - LogFile
PostPosted: July 19th, 2007, 12:01
I would like to start HDDScan from Scratch, select a disk to scan and save the logfile automatically. How to do it? The HDDScan.log was not generated in the directory from which I have started HDDScan when finishing the programme.
Thanks and best regards, Ernst
 Post subject: Re: HDDScan - LogFile
PostPosted: July 19th, 2007, 13:59
start help.bat
or HDDScan.exe -h
you have to create command line (bat-file, command line, sceduler etc.)
PostPosted: July 24th, 2007, 4:31
Thanks!
PostPosted: July 26th, 2007, 14:05
-Command line interpreter—
First command MUST be a drive number ex: 0 or 1 ...
-S Get S.M.A.R.T. data and write to SMART.txt
-AAM x Changing AAM, x=128-254, 0-disable AAM
-ARM x Changing ARM, x=1-254, 0-disable ARM
-PM x CHanging PM timer, x=0-255
-V x y z Verifycation. x= Start LBA y=End LBA or MAX z=Block Size
-R x y z Reading. x=Start LBA y=End LBA or MAX z=Block Size
-Mail x Sending e-mail with report, command take information from mail.ini
x-bit map parameters
bit 0 - it set include HDDScan.log into report
bit 1 - it set include SMART.txt into report
bit 3 and bit 2 -Alert level tor sending report
00 - Always send report
01 - Send report it unstable sectors found
10 - Send report if bad sectors found
Example: HDDScan 0 -AAM 128 -R 0 MAX 256 -S -mail 3
PostPosted: July 26th, 2007, 17:34
I can't believe I speaked English so bad :(
PostPosted: July 26th, 2007, 23:29
"Speaked"? :lol:
PostPosted: July 27th, 2007, 11:30
Steve wrote:
"Speaked"? :lol:
I guess now my English is a little bit better than before
may be I'm wrong :)
Anyway
my Russian is better than yours \m/ 8) \m/
just kidding :)
PostPosted: July 27th, 2007, 22:02
-AAM x x=128-254, 0-disable AAM
(Automatic Acoustic Management)*
-APM x x=1-254, 0-disable APM
(Advanced Power Management)**
-PM x x=0-255
(Power Management standby timeout)***
-V x y z Verifycation. x=Start-LBA. y=End-LBA or MAX z=Block-Size
-R x y z Reading. x=Start-LBA y=End-LBA or MAX z=Block-Size
-Mail x Send e-mail with report, take information from mail.ini
bit 0 - if set include HDDScan.log in report
bit 1 - if set include SMART.txt in report
bit 3 and bit 2 -Alert level for sending report
01 - Send report if unstable sectors found
Example:
Copyright: Rubtsov Artyom
Coding : Rubtsov Artyom and Sudakov Aleksej
Thanks to: Dmitry Postrigan and Sergei Kazanskij
Standards Definition (AT Attachment command set):
http://www.t13.org/Documents/UploadedDo ... A8-ACS.pdf
*AAM Automatic Acoustic Management
Level
Vendor Specific
1-127 Retired
128 Minimum acoustic emanation level
129-253 Intermediate acoustic management levels
254 Maximum performance
255 Reserved
performance may increase with increasing AM levels.
power consumption may decrease with decreasing AM .
AM levels may contain discrete bands. For example, a device may implement one acoustic management method from 80 to BF and a higher performance, higher AM method from level C0 to FE.
**APM
Decimal Level
0 Reserved
1 Minimum power consumption with Standby
2-127 Intermediate power management levels with Standby
128 Minimum power consumption without Standby
129-253 Intermediate power management levels without Standby
255 Reserved
performance may increase with increasing levels.
power consumption may increase with increasing levels.
For example, a device may implement one power management method from 128 to 160 and a higher performance, higher power consumption method from level 161 to 254.
levels 128 and higher do not permit the device to spin down to save power.
***Power Management standby timeout (Table 38)
0 Time-out disabled
1-240 (value * 5) seconds (i.e., 5 seconds to 1200 seconds)
241-251 ((value - 240) * 30) MINUTES (i.e., 30 minutes to 330 minutes)
252 minutes
253 Period between 8 hours and 12 hours
254 Reserved
255 21 min. 15 seconds
http://www.samsung.com/global/business/ ... tSeek.html
This information should also be placed on the web page for HDDSCAN
Users browsing this forum: No registered users and 120 guests
