 Post subject: Seagate 200G problem need help
PostPosted: August 1st, 2007, 4:15
Seagate ST3200827A 200G IDE
Firmware 3.AAE
Anyone know what is wrong? It keeps repeating the error message.
Interface task reset
4096k x 16 SDRAM
TONKA15 - 1_Disk S.59 12-09-05 11:07
Head Mask FFFF - Switch to full int.
Spin Ready
(P)PATA Reset
Master
AT Er 00 Nwt Er 43 RdWr 0058d.01.0000
ATA St 50 Er 01 Op 00 0,0000/0/00,00 01 00
Niwot: 97f29ff7 b6 97f29ff7.1.725 0000 005f 0000 0003
DiskAccess ReadSector EC=43 at 00058d.01.0000
CE Log ErrCode=43 LBA=61872a Type=5 Add To Pending 61872a
AT Er 00 Nwt Er 43 RdWr 0058d.01.0001
Niwot: 9ff79ff7 b6 9ff79ff7.1.725 0000 005f 0000 0003
DiskAccess ReadSector EC=43 at 00058d.01.0001
CE Log ErrCode=43 LBA=61872b Type=5 Add To Pending 61872b
AT Er 00 Nwt Er 43 RdWr 0058d.01.0002
DiskAccess ReadSector EC=43 at 00058d.01.0002
CE Log ErrCode=43 LBA=61872c Type=5 Add To Pending 61872c
AT Er 00 Nwt Er 43 RdWr 0058d.01.0003
DiskAccess ReadSector EC=43 at 00058d.01.0003
CE Log ErrCode=43 LBA=61872d Type=5 Add To Pending 61872d
AT Er 00 Nwt Er 43 RdWr 0058d.01.0004
Niwot: 9ff79ff7 b6 9ff79ff7.1.725 0000 005f Interface task reset
4096k x 16 SDRAM
 Post subject: Re: Seagate 200G problem need help
PostPosted: August 1st, 2007, 6:39
I think bad sector in SA or Dirty heads. Mostly i have seen this problem in Seagata hard disk.
DF :)
DF :)
www.datatracksystem.net
PostPosted: August 1st, 2007, 6:42
thanks DF, if SA have bad sectors how to fix? data is important. Dirty head? change MHA? Thanks
PostPosted: August 1st, 2007, 10:36
I think changing head should solve the problem as this is very common error in seagate hard disk.
DF
DF :)
PostPosted: August 1st, 2007, 12:39
It should be able to image, so go ahead and do it. :)
PostPosted: August 1st, 2007, 20:59
Starling, i have tried cloning it but failed. :cry:
PostPosted: August 2nd, 2007, 6:50
I work witk lot of seagate here.
it is unstable head. Change head will be the best solution.
Though you can clone it. it is extremely slow and impossible to clone with that condition because take a long long long time.
Спасибо
СУТИОНО / АПИНГ
PostPosted: August 2nd, 2007, 7:53
thank you guys i'll try
Users browsing this forum: No registered users and 72 guests
