Post new topic Reply to topic  [ 27 posts ]  Go to page 1, 2  Next
 Post subject: Toshiba MK6032GSX SATA with burnt CPU
PostPosted: August 3rd, 2007, 10:32
I have a Toshiba MK6032GSX SATA 2.5" drive that it's FUSE and CPU
are burnt out(Its visible on the chip).
I am aware of the fact that Toshiba drives keeps some critical information
like adaptive data inside the ROM. So swapping PCB or perhaps changing
the burnt CPU won't help to access the data
(I suppose that ROM is inside the burnt CPU chip).
Do you think there is a solution to recover data from this drive.
I appriciate any comment in this regard.
Thank you
 Post subject: Re: Toshiba MK6032GSX SATA with burnt CPU
PostPosted: August 3rd, 2007, 10:51
Check if you have external ROM on your PCB. It's an 8-pin chip.
If you have it you can swap it to another PCB and it should work.
PostPosted: August 3rd, 2007, 11:14
I thought the ROM info was in the "ARM" chip on the PCB?
That's what I've been led to believe on these.
I would like to be corrected if I'm wrong!!! ;-)
PostPosted: August 3rd, 2007, 11:17
Hi Starling,
Thank you for the reply. I think there is no external ROM on the PCB.
Please have a look at the PCB image and correct me if I am wrong.
Again, thanks for the advise.
PostPosted: August 3rd, 2007, 14:23
PCImage:
on some models (some GAS and GAX models) there is an external flash memory storing the FW, so it could have been true for this one.
Pninja:
Too bad it is not true in your case. U may try swapping the PCB and see if it is possible to read some sectors from the drive (probably not). If yes, then U will have to deal with the shifting points caused by the different translator...
It worked for me once but that was an old model (MAP).
regards,
PostPosted: August 3rd, 2007, 14:28
Then what could be done in these type of cases. is Raw recovery is time saving solution after cloning.
Very interesting post. Must be solved.
Df :)
DF :)
www.datatracksystem.net
PostPosted: August 4th, 2007, 6:51
Yep, I'm also interested in solving this type of case.
Thankfully Tosh PCB's don't fail very often, but when they do they are a pain in the ass!
PostPosted: August 4th, 2007, 9:40
pepe:
I swapped the PCB in the first place. It started endless clicking :( .
Pcimage, Darkforce1:
As you have mentioned, these type of problems
are really painful. You have your data intact on the platters but
you are not able to do a damn thing :cry:
PostPosted: August 4th, 2007, 9:51
AFAIK, the only way forward is so transfer the "ARM" chip containing the ROM info, onto a compatible PCB.
PostPosted: August 4th, 2007, 11:02
AFAIK,
As I said, the ARM chip(Processor) is fired.There is nothing left there to transfer.
PostPosted: August 4th, 2007, 11:05
PostPosted: August 4th, 2007, 11:13
Hello to all
See what I think that after changing head and PCB drive will detect now the problem will be of data. what I think that data will be recovered but only if you try RAW recovery. may be some files with proper name and data will come out but I think you have data but in raw format.
Waiting for PEPE sir's reply.
DF :)
DF :)
PostPosted: August 4th, 2007, 14:18
I could not figure out this thing up till now, but I am sure there is a solution.
PostPosted: August 5th, 2007, 6:24
darkforce1 wrote:
Hello to all
DF :)
darkforce1 sir,
Do you mean that the donor PCB is used altogether with its donor head(s) ? So it's more alike transplanting the platters to the donor drive, but in this case only using PCB and heads ? CMIIW
My Forum
PostPosted: August 5th, 2007, 7:32
Hi cryoborgofthevenus
why to transplant platter to doner. No I mean changing PCB only of head is not damage.
DF :)
DF :)
PostPosted: August 9th, 2007, 13:51
Can we transfer the platter to the donor and recover data in this type of drive if we match everything what has to be matched .this should give atleast some data reading success and with DE it should be better results.
PostPosted: August 9th, 2007, 16:20
In this hard disk all the impotent modules like Plist and Glist are in CPU as it is burned so thay are lost. So Changing head or PCB or swapping Platter will not help to get proper data.
DF :)
DF :)
PostPosted: August 9th, 2007, 18:13
DF :)
Glist cannot be in ROM, it's a Growing list ;-)
PostPosted: August 9th, 2007, 19:10
Thank you for correcting me.
DF :)
DF :)
PostPosted: August 10th, 2007, 5:33
Welcome friend ;-)
Users browsing this forum: Google [Bot] and 77 guests
