 Post subject: Replacing Maxtor DiamondMax Plux 9 PCB
PostPosted: August 8th, 2007, 13:58
Hi people in this forum, I'm quite new. Been reading the forums but without registering and in this case I need your help.
I own a DiamondMax Plus 9 (80 gb) with the following characteristics.
YAR41VW0
E4FYA
PCB Called: Calypso III
Because of a mistake, it was connected with the molex the wrong way and it never more started.
I really need the data stored in that drive so I acquired another HDD with the following characteristics
YAR41BW0
M6FYA
PCB Called: CALYPSO/KOI_P/THERM
I changed PCB's and now the broken HDD starts but it's recognized by the BIOS as "Maxtor Calypso" and detects no capacity and everything is in 0.
Could anyone please tell me what to do? I can't buy logic cards from another place because I am from Argentina and they don't ship here...
Please... help me, I need the data stored on the broken HDD...
 Post subject: Re: Replacing Maxtor DiamondMax Plux 9 PCB
PostPosted: August 8th, 2007, 15:20
Try to find another board. This one is not compatible.
Go to several local PC shops. Some of them have a large bin with old broken drives. Calypso is quite a common one, so you should find something. Make sure their drive at least spins up and has the same CPU type(Ardent C8-C1 for example) and then try that board on your drive.
Good luck.
PostPosted: August 8th, 2007, 16:22
No way to get it "compatible" ????
PostPosted: August 8th, 2007, 21:33
nan4k7 MSN me please. :D
Users browsing this forum: No registered users and 80 guests
